Monster MotorsportEM Tuning
    Sep 2013
    Bicester
    20
    2005 A3 wing mirror help!!
    Hi Guys,
    So some little scrote after the England match decicded he would kick my wing mirror off!
    Phoned some scrappies today and they've all asked me whether ithe replacement is for a 3 or 5 door
    I'm pretty sure they're going to be the same but can any one confirm for me please?
    I need a black electric and heated drivers side wing mirror for a 2004-2008 - if anyone knows of any about...
    cheers everyone!
    Lewbo's Avatar
    Aug 2009
    Hull
    1,039
    3 and 5 door mirrors have different base plates so maker sure it's of the same vehicle before buying.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Sep 2013
    Bicester
    20
    Cheers fella!
    Got new ones in today and managed to get the door card off and stuff..
    But how the f*ck do you get the wire through the door?!
    Lewbo's Avatar
    Aug 2009
    Hull
    1,039
    There's two ways to do this, 1st is to unplug mirror from door module, remove the electrical connector from the housing, just slide out, then take a photo of both sides of connections numbered 1-8 one side and 9-16 on the other if I remember right.
    Then disc disconnect each one by pushing the pin through the hole and pull out.
    Then Tape a draw wire on the cables and pull cable out from outside the car, it is hard as it's clipped in but does come out.
    Then on new mirror take of plug again and tape it to draw Wire and pull them back into the car. Use photo to remember connections and put back together and plug in job done.
    2nd is remove door frame from the door via all the bolts, then cable comes out with connector still on this way.
    Current
    previous
  1. Audi S3 1997 - 2003 Wing Mirrors Help
    By thassall4295 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2013, 22:14
  2. alloy wing mirror help
    By Shawny-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2012, 17:03
  3. A3 LED wing mirrors.. Help
    By smythey1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2011, 00:45
  4. passenger wing mirror help for 2001 S3
    By Scuba79 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2011, 13:41
  5. Wing Mirror Help
    By big_mo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2009, 13:37
