Sky InsuranceVolks Autos
Results 1 to 9 of 9
    Aqualea90's Avatar
    Apr 2014
    Do I need a new Diverter valve?
    I have read as many threads as I can on this and can't really find someone with the same symptoms.
    I have a revo cai installed and the car has started making this flutter noise under hard acceleration. It usually happens when you accelerate from lower revs and in 3rd. If I go from 2nd at high revs it goes fine. All things I have read say the flutter should happen when you lift off. I only get the big hiss when I lift off and get no flutter. So not too sure if it is actually meant to sound like that or not??
    Also, the main symptom which makes me think (hope) it's the dv is the fact it feels underpowered. It is remapped and I struggled to pull away from a 330d the other day whereas before this would have been an easy win... Sometimes it goes as normal, usually when I go from second at high revs. It almost feels like the turbo isn't kicking in for sone reason... Then when the revs get up you can feel it trying to go.
    Diverter valve? - YouTube
    That's the YouTube link to the flutter, apologies for the quality, you should be able to hear it and it is a lot louder in person!
    Also, it is going in soon for a new clutch/flywheel/thrust bearing. Don't know if that would be the cause if this though.
    Thanks in advance for any help guys.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,474
    have you removed and checked ?
    Aqualea90's Avatar
    Apr 2014
    No I was going to but have read it quite tricky?? Is it a quick enough job? 2009 s3
    Feb 2013
    Grimsby
    1,094
    isnt the diverter at the top front of the engine bay in the S3 with k04?
    05, A3 8P 2.0TFSI Quattro
    Aqualea90's Avatar
    Apr 2014
    Yes it is but it was just seeing if anyone else has experienced the same thing to save any hassle. I'll take it off and look tomorrow.
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    670
    By the sounds of the flutter that usually means requested boost is being made and the flutter is the boost level being maintained.
    Who's map is on the car?
    Due to the warmer temps cars aren't going as well as they do on cooler days and the other thought is how do you know the 330d wasn't mapped?
    IBIS WHITE S3
    Revo stage 2+ and loving it
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    Thats exactly what I was gonna say as a remapped 33Od is fairly rapid and will give a mapped S3 a run for its money.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Feb 2013
    Grimsby
    1,094
    Quote Originally Posted by Brodster View Post
    also diesels are far easier to drive to max power. Petrols are much less forgiving.
    Aqualea90's Avatar
    Apr 2014
    Yes I did think that the 330 could have been mapped but just the fact the car hasn't been feeling right the past couple of days. Weather has been good tbh but didn't think it would have had that big of an influence.
    Its a Torquetronix remap done apparently around 20-25k ago. Should I try putting the old intake on and see if it makes any difference? Along with checking the DV? Or do you not think that is the issue?
    When I got the car it just felt like the power was relentless, but now it just feels a bit dead sometimes.
  1. New Diverter Valve 'D' installed!
    By Audi-Rog in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2014, 21:08
  2. Turbo stall? Do I need a new diverter?
    By Bad Sir Culation in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2014, 14:07
  3. dump valve. i need a new one.
    By chrisa4quat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th August 2011, 21:58
  4. New Product: APR R1 Diverter Valve 85+vat
    By awesomeade in forum Awesome GTI
    Last Post: 13th June 2007, 15:09
  5. HELP needed replacing bosch diverter valve ?
    By AUDI@WRC in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2007, 14:28
