Sky InsuranceVolks Autos
Results 1 to 15 of 15
Like Tree8Likes
  • 1 Post By GGG_666
  • 1 Post By GGG_666
  • 3 Post By wuta3
  • 2 Post By S3Alex
  • 1 Post By RS3dan
Thread: Murder It build
    GGG_666's Avatar
    Nov 2013
    Cambridge
    67
    Murder It build
    Hello all! I'm Geoff and live in Cambridge
    Been on here for a bit now but I'm one of the quiet ones. Figured I'd share some progress on my car
    This isn't my first car build. I lived in Japan for 6 years and had a Toyota Starlet GT (1.3 turbo) then moved to the UK and had a MK4 VW Golf GTI with coilovers, ARBs, FMIC, TBE, Intake, Re-map. I got a new clutch installed and then for some reason I decided to drive it into a brick fence (thank you black ice) At the same time as the Golf I had a 450+HP S15 Nissan Silvia that is now sold and now I have my 2006 A3 2.0T 6 speed quattro
    When I first bought it
    Straight away I knew what I wanted....to get it like my Golf was
    Enter my first set up. H&R premium performance coilovers with H&R ARBs and Miro STP2 wheels (fake splits) (19x8.5 front and 19x9.5 rear ET48) I also de-baged the front with a FK grill and the rear with the missus hair dryer, dental floss and some WD40 and also installed a ATP turbo 3" intake
    Here it is without spacers
    Then I added spacer 15mm front and 17.5mm rear. Yes this rubbed/scrubbed a lot (also moved house in case you can't tell)
    At this point I also had HID lights installed along with LED interior and exterior
    I really didn't like the H&R coilovers, they felt too soft for me since they had progressive spings so I did more research and found BC Racing coilovers with 10k springs. Out with the old and in with the new. Shortly after fitting the new suspension I decided I wanted some new wheels because I was getting tired of the tyres rubbing with the over aggressive fit.
    I found VMRs to be fairly inexpensive and decent looking so I ordered a set of the V701s 19x8.5 ET45. When they arrived one of them was dented/chipped so the guys at VMR sent me a new one and let me keep the damaged one. Figuring that I'd have to get it repaird to run it as a full size spare I decided to get them all powder coated satin black (powder coated wheel is on the left in the picture)
    While the wheels were in limbo I started researching re-maps and exhausts and decided to go to AmD for a TBE Miltek and stage 2 re-map
    Decided at this point to get an oil catch/pcv re-vamp kit. I went with CTS Motorsports Catch Can. The only problem with theirs is that it's not made for Euro spec cars with the fuel vapor catch. Luckily I have a friend that's handy at welding and he whipped up a litte tubeuler bracket and bolted it down near the battery box
    I also did a rear wiper delete from these guys
    Willkommen - Heckwischerabdeckung, Blindstopfen, Kappe, Glasstopfen, De-wiper, Plug, Grommet, Cap?
    Then put my new wheels on
    No spacers
    I aslo had the car detailed by Cabridge Valet Center becasue I was too scared to go at the car with a buffer on my own
    CLEAN!
    When the car was in for detail I pulled the wheels off becasue I needed new tyres and then added spacers when I put the wheels back on. ECS Tuning 8mm front and 10mm rear spacers. I get a little scrubbing from these as it's now ET37 front and ET35 rear but these will be coming off after GTI International.
    clean engine now too
    New wheels and coilovers=alignment issues. I ran thru a set of tyres in a matter of 2 months even with an alignment being done. I was told that my camber couldn't be adjusted any more on the stock arms.....so back to the researching and I came up with these
    034 Motorsports rear upper control arms. They add an additional 5 degrees of adjustment
    and decided while I'm at it I might as well do the lower arms too. Megan Racing rear lower toe arms
    Back to AmD for install and a laser alignment
    So that's where I stand now.
    Next on the list
    tinting rear lights
    034 motorsport shift knob
    clutch/flywheel (still deciding which one)
    CTS Turbo short shifter and FMIC
    HPFP with stage 2+ tune
    If you see me around, say hi...wave...flash (your lights only please)
    any suggestions I'm open ears
    Compkiler likes this.
    Feb 2012
    331
    nice motor mate, mods look good too, not so sure on the front grille tho...
    Jason-3.2's Avatar
    May 2012
    Bracknell
    176
    Love the front grill, looks good.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,061
    Looks lovely, any chance of a straight side-on shot for stance oggling?
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Sep 2009
    Trotters, Peckham
    539
    you lost me at the front grill
    GGG_666's Avatar
    Nov 2013
    Cambridge
    67
    Quote Originally Posted by wuta3 View Post
    I'll get a pic over the weekend
    GGG_666's Avatar
    Nov 2013
    Cambridge
    67
    mitalm likes this.
    wuta3's Avatar
    Jul 2012
    1,061
    Quote Originally Posted by GGG_666 View Post
    Nice GGG_666, a bit low for me but with those wheels it looks cracking. You need bigger brakes though to fill them out.
    GGG_666's Avatar
    Nov 2013
    Cambridge
    67
    Thanks! Its tough trying to get a mix of "form and function"
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    Thats true.....very easy to get too much show,and not enough go,but I think you're well on the right side of that.
    And,I can see you've been to my car's favourite holiday destination.....
    wuta3's Avatar
    Jul 2012
    1,061
    Quote Originally Posted by S3Alex View Post
    Alex is secretly an AMD shareholder.
    S3Alex, GGG_666 and Ron burgundy like this.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,360
    LOL....I have no say in the matter...my car insists.
    RS3dan's Avatar
    Mar 2014
    Warwickshire
    78
    Great looking car mate, good work
    S3Alex likes this.
    GGG_666's Avatar
    Nov 2013
    Cambridge
    67
    uploadfromtaptalk1404572772871.jpgGTI International today
    GGG_666's Avatar
    Nov 2013
    Cambridge
    67
    Thanks all!
  1. How long from build week to on my drive?
    By JSportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2004, 00:23
  2. ice build up in A4 Avant Quattro wagon fenders
    By imported_JGalt in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2004, 10:46
  3. MOVED: ice build up in A4 Avant Quattro wagon fenders
    By imported_JGalt in forum General Chat
    Last Post: 30th August 2004, 22:49
  4. Build of a new A3 - check points
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2004, 14:16
  5. A3/S3 kick builds
    By will_S3 in forum In-Car Entertainment
    Last Post: 6th June 2003, 13:55
