AH FabricationsBadger5
    Mar 2014
    6
    Emissions control system warning light?
    Hi guys i have a 59 plate audi a3 1.9 tdi and tonight
    driving home the emissions control system warning light came on any ideas?
    thanks dan
    Feb 2012
    338
    If your car has DPF take for a motorway run, preferably 1hr or more
    Jun 2014
    I've an 58 plate and the same happened me. Light came on, I also found that I would lose power when I reached high revs in any gear, 3000RPM or more and that this probem was intermittent.
    In the end, I got VAGCOM done on it last week and it came up that I needed to change the DPF output sensor. Changed this (£115 in all) and it seems to have worked. It's not guarenteed to work though and I was told that the DPF itself could be ruined but it seems to have worked!
  1. Emission Control System Warning Light / S3 8P
    By s3_trev in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2014, 23:08
  2. Emission Control System warning light came on and stays on
    By ecnirp98 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2013, 21:27
  3. Replies: 3
    Last Post: 1st December 2012, 22:14
  4. Replies: 7
    Last Post: 1st February 2012, 13:09
  5. emission control system warning light flashing............
    By tisinthepark in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2011, 17:02
