So im looking at my rear lights, they are just the normal bulb ones and i have 2 bulbs either side which act as both normal AND the break lights.
So when i brake, the lights get brighter, now im guessing this is because the voltage is increased from 6v? to the normal 12v to make the brightness change.
Now my thought is, because im a cheap guy, i could wire/soldier in some led strips (either red or white not sure yet) stuck inside the housing with a resistor(so no bulb out errors) for like under a tenner easily, and they would still get brighter and dim the same.
Im just putting this idea across is electronically this would work, im guessing it would? and maybe if someone can point me to the correct resistor i would need would be great for my retro fitting
Cheers.
Cheers.
