    May 2014
    106
    Led number plate lights
    I know this had been covered and I have found answers but only from a few years ago,
    i bought canbus error error led number plate lights which I fitted and don't seem to
    work. Put old ones back in and still don't work!!
    do I really need to get it on the computer to clear the fault so I can fit standards back in or is there a solution to this??
    cheers guys
    Sportback owner
    Apr 2007
    France
    496
    Charlie, if you put two known good (tested) normal bulbs in, and then cycle the ignition, then turn on the lights, they should work OK. The canbus had detected a blown/missing bulb(s), and has turned off the 12volt supply. The canbus will continue to look for two good bulbs, and when it finds them, on will come the supply. With the LED bulbs, are you sure you put them in the right way around?
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    May 2014
    106
    Aww I get you thank you for that.
    And they are not led bulbs complete units with led's bulit in to them, and can only fit 1 way haha.
    Perhaps clear the cycle and start again???
    Jan 2012
    1,837
    There is a mahooooosive thread about the OEM Led units, fit them.
  1. led number plate lights
    By mitch_h_88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th October 2010, 22:50
  2. AUDI A3 LED NUMBER PLATE LIGHT REPLACEMANTS
    By philipjmarshall in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th June 2010, 21:31
  3. led number plate lights
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2010, 13:40
  4. LED number plate Lights....help!!!!
    By V16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2010, 21:07
  5. New Type LED Number Plate Lights
    By david_phillips95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2009, 14:26
