EM TuningSky Insurance
Results 1 to 9 of 9
    May 2014
    108
    Question S3 clutch fault ??
    Hi guys just bought my S3 2007 a week ago, and been out in it alot this weekend, gave it abit off beans now and then abd it seems the clutch pedal is getting closer and closer to the floor on take off. Seems then after a short easy drive be ok again?
    have noticed abit of a clunk some times when driving like miss daisy and changing gears also?
    would first protocall be looking at mounts and get the clutch fluid changed and bleed it, or does that sound like clutch is nearly on its way out?
    only asking as most cars the clutch seems tomget highter when they om there way out mine is geting lower?
    i also had 3 months warranty would this be covered do you think?
    all help would be much appreciated
    Ron burgundy's Avatar
    Mar 2014
    418
    If you've got a 3 month warranty from a trader then you should be covered .
    Some people deserve to have eggs thrown at them....brick shaped eggs...made out of brick.
    Grilled Haloumi....mmmmm
    May 2014
    108
    Looks like fly wheel is covered but not clutch!! Grrrr
    Does it sound like clutch tho as the pedal is Geting closer to the floor rather than high??
    May 2014
    108
    Just a quick update if anyone can advise???
    It seems to only get low after giving it some beans in 1st and 2nd??
    But then drive nice for 2 minutes and the clutch seems to go back to normal?
    Could it be master or slave cylinder?
    May 2014
    108
    Any one experienced this before?????
    Dec 2013
    142
    I have an 09 model and sometimes if I clutch in really quick at low speeds (parking lots, slow in busy traffic) I hear a clunk with squeek type noise. Sounds even worse in undercover car parks. Don't like the sound of it so will get it checked out soon. Only 40k kms on the odom. 2nd owner.
    May 2014
    108
    Doesn't sound good does it mate,
    Are these the correct part numbers for the updated Sachs clutch?
    883082 999787 -cover
    881864 999502 -plate
    Any one with fly wheel pt no and concentric slave pt no would be grateful.
    Thank you
    May 2014
    108
    Bit of a quick look underneath and I can see abit of a leak from the transfer box I think it is?
    Or is there something above that that's leaking on to it? Pictures added .image.jpg
    May 2014
    108
    No one??
  1. Strange clutch or gearbox fault. Can anyone help?
    By Graham89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2014, 00:37
  2. Clutch switch fault ??
    By clarky87xx in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th July 2013, 18:10
  3. air con clutch or control module fault???
    By Markeyboy in forum Air Conditioning
    Last Post: 16th February 2013, 07:22
  4. Clutch pedal fault??
    By becks2012 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2012, 19:35
  5. DSG Fault A3 8P - Clutch temperature monitoring & Transmission Input Speed Sensor
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th June 2008, 18:54
