hi guys
i have ordered my self tyrolsport deadset subframe bolts and washers , the reason for this is i have had alot of movment in my subframe you can see were the frame has been. and also once its tight its so much quiteter on the road.
1st i retightend the current bolts as thay were loose , this was ok for a week . then back to how it was.
2nd i brought some ECS spacers and a set of new bolts this was ok for 2 to 3 weeks then back to how it was .
3rd i have ordered some tyrolosport dead set kit , and i hope this stops the issue , although alittle expensive .
i understand the issues with alinenment after the kit is fitted , but i will takle that one when/if it comes to it .
i have been tralling through mk5 r32 forums and so many suffer from this , and thay have also tried the ecs kit , works for some not for others .
if you guys are interested i will keep you posted .
my car is the 3.2 v6
ray
ray
