    kaliber's Avatar
    kaliber
    Sep 2009
    harrow
    26
    DIY door replacement advice please
    i have a significantly large dent in my drivers side door and i have found a same-colour cheap door shell on ebay.
    Is this a matter of prizing-off a few parts and unscrewing some screws to replace the door shell or am i just heading into a minefield considering i am going to have to contend with changing the door locks and window mechanism's, etc.
    any advise would be greatly recommended, i really want to stay clear of expensive costs at the bodyshop.
    27,113
    You will need to swap everything across if its the whole door.
    kaliber's Avatar
    kaliber
    Sep 2009
    harrow
    26
    ok thanks, how difficult is this going to be do you think.
    i have changed bumpers and do my own servicing but i am not familiar with this sort of task. is this something you recommend as 'DIY' or best left to the pro's?
    27,113
    I don't know your level of technical ability mate, but door top of, looms pulled through, motor removed, door lock etc.
    I can do for you if interested, takes a little while & you would have to help just to hang the door itself & rest I can do & remove any errors on the cars systems.
    I have a job coming up in Harrow shortly for brakes systems, so can maybe do the same day.
    Oct 2009
    Stanmore, London
    30
    Have you thought about trying paintless dent removal?
  1. looking to buy audi a3 2.0tdi sport 3 door any buying advice please
    By conorw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2012, 12:23
  2. driver side door rubber seal replacement help please
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2010, 08:30
  3. Door lock problem, advice please?
    By Trigger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2010, 14:50
  4. Drivers door window regulator broken - advice please
    By bebecheekymonkey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th January 2009, 23:53
  5. DIY Suspension - advice please
    By Teejay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2008, 20:20
