For the last few months I've had a slightly annoying 'rough' shutdown when I turn off the engine.
Initially I was convinced I had an issue with a leaking EGR valve as the engine seemed to shut down a lot smoother when the engine was turned off during a regen, however after fitting a new ASV & EGR + gaskets the problem remains. After testing with VCDS the EGR & ASV appear to be operating correctly but the rough shutdown persists.
I've tried doing the sequential output tests & all solenoids & valves work ok, however when I do the ASV test the valve slams shut as it should (I've physically got my fingers in there to check it with the boost pipe off) but the engine still coughs & splutters on for a bit before shutting off (extremely roughly).
Now I'm left wondering where do I go from here? What is left to check? Is it worth removing the inlet manifold? I've found no evidence of it leaking, although my MPG has been utter sh*t recently & my DPF regens have got a bit out of hand of late although this could be a dodgy sensor. The only recent changes to the car have been a new air filter & a new battery after it died overnight, so I'm totally stumped as what is going on
