Monster MotorsportBadger5
    May 2014
    Thumbs up I have 2 fault codes can anyone help?
    Hi guys
    I brought a code reader over the weekend, one because my air con isn't working its blowing hot out of the passenger vents no matter what but the drivers vents work fine at all temperatures so i plugged it in and this come up
    Does anyone know how to fix this issue, i have read somewhere the issue lies behind the glovebox there is a motor that jams up?
    Is this correct ?
    Also i found this fault but i have no idea about it...
    Any help on these i would appreciate it so i can get them rid!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    yes behind glove box
    1 or 2 of the flap motors will have jammed or broke
    remove glovebox and take it from there
  1. 2 Vagcom Fault Codes....Can anyone diagnose / help?
    By LSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2012, 00:49
  2. Fault codes can anybody help ?
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2011, 19:53
  3. can anyone help.mk5 golf vag-codes
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th November 2009, 21:14
  4. dash says SAFE - can anyone help code my keys?
    By M7R in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd May 2009, 13:54
  5. CAN ANYONE HELP?? VAG COM FOUND A FAULT!
    By grays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2007, 21:48
