Hello People,
Done a scan on the S3 today and this fault code came up, Could you tell me what it is or the possible causes.
Car Is running correctly and as should never missed a beat since i've had it.
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0INFNA10J
Coding: 0103000C1C0F0160
Shop #: WSC 00772 129 00000
VCID: 80096769D336311E1B7-80D5
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 72979 km
Time Indication: 0
Date: 2014.05.15
Time: 13:35:28
Freeze Frame:
RPM: 814 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 43.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.716 V
Readiness: 0000 0000
Cheers Once again.
Dan
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 72979 km
Time Indication: 0
Date: 2014.05.15
Time: 13:35:28
Freeze Frame:
RPM: 814 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 43.0°C
Voltage: 13.716 V
Cheers Once again.
Dan
