Volks AutosAH Fabrications
Thread: ESP fault.
    Mar 2014
    39
    ESP fault.
    Pulled out of a junction quite quickly this morning, "ESP fault" popped up on the DIS, immediately pulled into a car park I was passing sat idle for 5 minutes or so, turned the car off for 2 minutes, waited, started again still there had somewhere to be so I nursed it out the car park back onto the road after a minute or so it disappeared never to be seen again, gave it the beans a little bit on the way home didn't re-appear.
    Anyone had this issue or none issue as the case may be before? read somewhere that sometimes if the battery is low it can make it pop up no idea if that's correct?
    Mar 2014
    39
    nobody?
    Jan 2014
    Norfolk
    68
    Quote Originally Posted by wilsons3 View Post
    nobody?
    I had this on my a3 2007 2.0 tdi sline 140
    Sent it to the dealer and It turned out to be corroded abs sensor and had my hub replaced too never had a problem since
    My abs light use to come on wen I hit around 50-70 mph If it comes back on check your abs sensors clean them up and check your hub
    Audi a3 s line 140 bhp 2007 red. Jabba Sport remap 180 bhp, red carbon fibre wrap ,interior trim ,team heko wind deflectors, xenon bulbs white / ice blue , red audi badge , completely debadged on the rear , led mods in all footwells red , 18" s line rims , red alloy gaters , black plasti dip front grill ,
    May 2014
    Worth getting it scanned to see if any codes appear. It seems to be quite a common issue. I had it on mine recently and it was linked to the ignition coil, so I had the coil pack and spark plugs replaced. There are a few threads on here about it, however, that's once knowing the fault codes.
    Good luck
  1. S3 esp fault
    By Yonner in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2009, 11:25
  2. Audi S4 4.2 V8 ESP Fault...HELP!
    By Reddwarffan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th April 2009, 15:23
  3. ESP Fault on A6 (C6)
    By EddyH in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd November 2008, 22:34
  4. ESP Fault, Steering Fault - Re Retro Fit Cruise! Help Please
    By J7-AUDIA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2008, 12:17
  5. ESP Fault code
    By Jay in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st January 2008, 11:15
