EM TuningVolks Autos
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By syko
Thread: A3 2.0T 55 reg diverter vavlve issue??? please help people mind ticking away
    Oct 2013
    14
    Hi all thanks for taking your time to help me, however when i am accelerating i can hear my turbo whistling more than normal( whistling inside the car with radio on) i have heard and read alot about the diverter valve revision D, i assume my has the c one on has cannot see any receipt for this. my questions are
    1- Will my turbo blow/break if the diverter valve is split on the inner seal and not boosting right
    2- IF the diverter valve was leaking would i bring the eml light on?
    3- if it is the diverter valave that needs changing how easy is it to do on the 2.0 T or would it be better going to garage.
    4- my car does seem like its not boosting 100%
    any help advise would be great
    Apr 2014
    10
    A 55 plate would have a diaphram style which do split and leak you want to replace it for the newer revised G (06F 145 710G = audi part number)
    Simple job but need to be under the car ...if you google there is a guide to replace
    wuta3 likes this.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,072
    As Syko said...Also, if you do this on the drive, unlike the S3 the 2.0T DV location is retarded. Best option I found was to take off the drivers side wheel and wheel-arch lining and access from there. Total PITA.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    679
    As above and doesn't always bring on the warning light.
    No it won't ruin your turbo.
    On the engine with the diverter on the turbo I'd go rev d without the diaphram as it's more robust against the extra heat down there.
    IBIS WHITE S3
    Revo stage 2+ and loving it
    Jul 2012
    Cheshire/N Staffs
    1,343
    Personally I would have gone for a Rev D Piston type DV.
    06H 145 710 D
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Has the engine performance dropped?
    Feb 2013
    Grimsby
    1,099
    i changed mine on my A3, its a ball ache to get to but i just jacked drivers side up, slid under and faffed with alen keys. After 4 hand cramps later it was done tho!
    When i got mine mapped unicorn remapping put a D in it, probably caus its located on the turbo where its very HOT lol
    05, A3 8P 2.0TFSI Quattro
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    Quote Originally Posted by wuta3 View Post
    How long did it take to change the DV? Any special tools needed? regards
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Jan 2014
    51
    Takes 10 minutes, no need to remove anything. Just jack the car up, or use ramps, get underneath then take out the 3 bolts (the difficult bit) and disconnect the plug. It helps to use your other arm if you cant quite get the right angle. Make sure the engine is cold so you dont burn your forearm though
    2.0 TFSI / Go Fast Bits Atomic / Go Fast Bits DV+ / Precat Delete / MAP Diode Mod / 250hp@19psi / Stock Software
    sliced's Avatar
    Jun 2012
    1,217
    Cheers mate, sounds a lot easier than what i've read previously. Brotek has given me a very tasty price for the dv+, may just have to get it soon :D
  1. Starter Motor issue??? Please help!!!
    By Lion Heart in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2011, 15:38
  2. Air Con Issues ***please help***
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2010, 08:48
  3. Missing in idle - major issue please help
    By urban-audi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th December 2009, 17:10
  4. Ignition/immob issue, please help!
    By Jimmeh in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2008, 10:25
  5. Braking Issue Please help
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2005, 13:23
