I have a 5 DR 1.6 Tdi S-Line 2011 , Remap says I can get 145HP + 320nm but what does the DPF delete do? And what kind of 0-60 times would I get? Thanks alot guys!
Half answered your own question there mate - a DPF Delete is actually removing it completely and replacing it with a straight pipe which is now an MOT fail. You need to get your DPF "gutted" - they cut it open, gut it / remove the internals and then reweld it shut. The MOT of a DPF is a visual check to see if its present, which if welded up properly they wont notice its been gutted.
No clue with 0-60 times but once mapped it will be like a new car
