ItsAllGood
So after going to the breakers and bought a set of 2006 bi xenon. For a good price. Lucky as i found this, i researched the net on how to proceed next. I then bought the kufatec adapters. Then there comes the long wait. Whilst waiting, i stumbled across in here that the bi xenons wont work on A. rev. comfort modules. And need a K.. Someone has done the upgrade to K module, which didnt look easy, regarding to all the fault codes showing up. The car i took the headlights from had a D. rev. So i assume, buying that module will make my lights work, ye? Comparing the D and the K, is it the same procedure? Just plug all the connectors out from A and move them over to the D? And hopefully not get errors? Will the D module give less, hopefully no errors? Apreciate all the support, thanks
