Monster MotorsportChris Nott
    Mar 2014
    Locking switch on front passenger door
    Hi to everyone on Audi Sport! A brilliant forum.
    I had a thought that it may be nice to have a duplicate lock/ unlock button on the passenger front door, so that the passenger can also have this facility to hand if necessary.
    The button and trim is available on left hand drive cars state side, so parts shouldn't be an issue. It's just if the passenger door controller can be coded to suit?
    If anyone has any idea's, then please share.
    A3 8P 2010' SB
    Mar 2014
    Anyone had any thoughts?
    mechanic69's Avatar
    Mar 2007
    419
    Quote Originally Posted by Cyberman_uk View Post
    My thoughts would be the space is there for the left handers but the door controllers and wiring are sided???
    S3 - Sprint Blue BE [MY11] My Build Thread
    Options - Satnav, Bluetooth, MFSW, Privacy Glass, Nappa Leather
    Mods - Bluefin Stage 1, DV+, Revo CIA, Loba HPFP, PCV Delete, Cruise, TPMS, Bilstein B8s, Eibach Pro Kit, H&M Spacers, Exclusive Leather Trims
    Future - Downpipe sports CAT, Stage 2+/3, Brakes, ALK, ARB, Hybrid turbo, 2nd Mortgage
    Mar 2014
    Yes agree. There is room in the door trim. And you're right there wouldn't be any wiring present, but the loom must be available from a LHD model as maybe is the controller. As with a few things like ambient lighting and door puddle lights, which can be retro fitted and coded into the door module, I thought it may be possible to do.
    Or even put a door module from the RHD drivers door into the passenger door?
    Maybe Nigel (NHN) would have an idea if this is possible
    Thanks.
    mechanic69's Avatar
    Mar 2007
    419
    Thanks.
    I would have thought the looms are sided too, but you may be able to add a right sided loom and controller. the main loom must have the wiring for both sides??
    Can you get to the connection to the main loom? If theres a plug and socket see how many wires go in and out, compare with drivers door and you should have an answer. If theres no plug you no the main loom is also sided.
  1. front passenger door removal
    By jimmcgee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th October 2013, 00:38
  2. How hard is it to fit a new front passenger door?
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2012, 22:30
  3. Strange electrical problem with my front passenger door.....
    By Az in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd August 2011, 19:32
  4. Front passenger seat removal on 3 door S3
    By Roswell in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2011, 23:05
  5. Front passengers door lost power???
    By norad97 in forum Volkswagen and other VAG
    Last Post: 28th January 2010, 01:32
