AH FabricationsVolks Autos
    Apr 2014
    29
    apparently turbo leaking oil into air system??
    took my a3 to have the egr valve cleaned out today, and when i went to pick the car up the mechanic told me that the turbo is leaking oil into the air system... not sure what to do or what to believe, could anyone help me out, if this is true does it mean my cars ****ed or is the turbo on its way out?? what damage will it actually do? cheers
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    All turbos leak a bit of oil vapour into the intercooler/intake system, as long as it's not dropping large amounts in (does your oil level drop rapidly?) it's not really an issue.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Apr 2014
    29
    Quote Originally Posted by max69vk View Post
    Cheers for your reply mate, my oil levels havent seemed to drop and i use the car daily, ill check it in abit and have alook, i have read that its normal for alittle leak, but im juat wondering if the guys that done it are just cowboys and trying to get abit of coin out of me, ill check my oil today and ill monitor it for a few days see if it dropa rapidly or not, cheers mate
  1. Sucking air into coolant system
    By abiggerjimjr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th April 2013, 18:59
  2. turbo hoses leaking oil?
    By maffew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2013, 18:00
  3. Bleeding oil into NEW turbo!!
    By nathan_wilson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2012, 19:57
  4. Air Drawing into Diesel System?
    By Pedro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd October 2010, 16:57
  5. k03 leaking oil
    By simon_golf_tt in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 23:39
