JMB RetrofitsEM Tuning
    May 2014
    13
    Rev Counter Position when Idle.
    What should be the rev counter position when the car is started? May sound daft but does everyone's sit at zero?
    I've just noticed today than mine is sitting at just under the 1000 marker.
    Possible causes? Only had the car a week.
    Jan 2012
    1,837
    Mine idles at 777rpm going by VCDS. 1.9 TDI.
    When stone cold it will idle at around 1000rpm until warmed up when it drops to a solid 777.
    During a DPF regen it may idle slightly higher than 1000rpm. If you stated the engine you have?
    May 2014
    13
    Cheers Chris. Mine is sitting around the 800 mark at idle. Also a 1.9 TDI.
    Jan 2012
    Central Scotland
    40
    800 - 1000 rpm depending on engine/ambient temps. Might sit a zero if you have petrol and start/stop technology but not sure they even had that option on 8P.
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    Follow SmithyAG On Twitter
    820 (-/+ 10) in normal conditions on 2.0TDI.
    As above, can vary with ambient temps and load on the alternator.
  1. Rising and falling rev counter needle on idle
    By northern monkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2010, 10:13
  2. Rev counter sticking,Idle problem
    By Mick a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2009, 00:43
  3. Seating position when driving fast. Turnfast web
    By rodfj in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2009, 19:02
  4. Variable revs when idle !?!?!
    By Mikebabs1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th May 2009, 16:36
  5. Abs warning, no aircon or rev counter
    By imported_rst99 in forum General Technical / How To
    Last Post: 2nd August 2004, 09:30
