Volks AutosSky Insurance
Page 3 of 3 FirstFirst 123
Results 81 to 92 of 92
Like Tree29Likes
Thread: Preventing carbon build up [2.0 TFSI]
  1. #81
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,425
    Quote Originally Posted by cnahamilton View Post
    Right well im hazzarding a guess that mine will defo need doing as mine just just clocked 120k. S3Alex - this walnut blasting is it something i could do or will it cost more in gear than get a garage to do it?? i am very competent with engines/cars as i build classic fast road and race engines for minis and midgets
    USP Motorsports sell a relatively cheap DIY kit,but the real deal is having it properly done,and I believe for around £200 or less.
  3. #82
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,425
    Yeah wouldnt be a bad idea. Not sure if i would get enough in my area of the country. middle of the suffolk farmlands lol. Does amd offer the service??
    Best to approach them and see what they can do.
  4. #83
    Jul 2013
    104
    Anyone know of anyone in the Southampton area that offers the de-coke service? What's the proper terminology for this service anyway?
    I'm pretty sure my PCV has gone as well, so I might replace that at the same time. Although, I could probably do that myself.
  5. #84
    Jun 2014
    12
    hi anyone try it terraclean any feed back pls
  6. #85
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,425
    Quote Originally Posted by leeds lad View Post
    If you're talking about their intake valve cleaning product,it's something that needs to be injected into the intake,after the MAF,and is supposed to break up carbon deposits on the valves.
    Personally,I have no knowledge of the product,and there's very little in the way of feedback on the net,but I can't see how a spray is going to deal with hard,burnt-in deposits on the valves.
    The other product they have is introduced via the injectors,and won't work on direct injection systems.
    I know which I'm happy with.
  7. #86
    Jul 2013
    104
    I'm pretty sure my PCV has gone as well, so I might replace that at the same time. Anyone know what the part number is for the current 8P compatible revision?
  8. #87
    Jul 2013
    104
    I've read else where that it's a good idea to replace the N80 Evaporative Emissions Control Valve as well. Do you guys agree? If so, anyone got the part number for the latest compatible revision?
  9. #88
    Sep 2009
    Trotters, Peckham
    539
    just my humble opinion but if you want your carbon gone there is only one effective way of doing it...elbow grease every 20K for me
  10. #89
    Jul 2013
    104
    Quote Originally Posted by tcardio View Post
    If only I had the know how and the guts.
  11. #90
    Jul 2013
    104
    Well just in case anyone else is facing the same issue...
    I replaced my Positive Crankcase Ventilation (PVC) valve tonight, which not only resolved an issue where the car was idling rough at 800-900RPM and hunting up to around 1300RPM, but it restored a fair bit of boost, improved engine response and smoothed out performance when letting my foot off the throttle. Very happy indeed. Especially as it was a five minute job for anyone who can turn a screwdriver!
    So anyways, the handy info I have are the current part numbers, as supplied to me by Southampton TPS (a.k.a The Trade Parts Specialists). These guys are the most professional supplier of OEM parts I've dealt with. Many of the garages/workshops in Southampton get their parts from these guys. That's how I found out about them. Anyway, enough friendly promotion. Here are those part numbers:
    PCV valve cover assembly: 06F 129 101 P = £32.24 inc VAT
    PCV valve cover gasket: 06F 103 483 E = £16.78 inc VAT
    PCV valve cover to turbo hose: 06F 103 215 B
    PCV tube to turbo metal gasket: 06F 145 757 F
    I actually only bought and replaced the PCV valve cover assembly and the PCV valve cover gasket (always best practice to replace gaskets and seals when replacing the associated parts), which came to less than £57 inc VAT. But if I remember correctly, all four parts would've come in at around £80. Considering other older revisions of the PCV alone on eBay were shifting for £45 inc postage, I'd say going to Southampton TPS was a much better choice. I hear they're pretty good when it comes to returning parts you might've bought that were not correct for your car.
    Result!
    Hope this info helps someone.
  12. #91
    Jun 2013
    Central Scotland
    96
    This might be worth considering. I had this done recently at my last service, only around £65 to have it done. Definetely noticed a difference aftter in relation to general running and idling of the car. A lot smoother afterwards.
    Relatively an easy fix too.
    https://www.youtube.com/watch?v=vaDh...&feature=share
  13. #92
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    692
    Quote Originally Posted by Doogie... View Post
    Would be good to see the insides of the inlet valves after the chemical clean to compare against the walnut blasting cleaning.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
  1. Is there a Carbon Build Up Fix as yet?
    By _G_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2012, 20:51
  2. Turbo Carbon Build Up? + Doors Not Catching?
    By Gavin G in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2011, 06:00
  3. carbon build up on RS4 FSI
    By JAJ in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 5th June 2011, 11:55
  4. carbon build up on RS4 FSI
    Last Post: 30th May 2011, 20:41
  5. Carbon Build Up On ALL VAG FSI Engines??
    By FingerS o FuDgE in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th September 2010, 19:16
