Volks AutosChris Nott
Results 1 to 7 of 7
    May 2009
    south yorkshire
    628
    foot well lights correct operation.
    whilst fitting rear headrest screens for the kids + usb input to rnse i decided to fit the footwell lights , bought from china £16 delivered Led version with loom , connected power to black plug pin 7 .
    did coding in vcds for led footwell lights both bytes.
    if i put ignition on the illuminate for a few seconds then go out . are they not supposed to stay on whilst the headlights are on ,or are they only illuminated when the door is opened like the puddle lamps ?
    Lewbo's Avatar
    Aug 2009
    Hull
    1,051
    Do you have a link to tear but yes that's the correct operation, had them fitted on my S3 which where from factory, my mate has a scirocco with footwell lights and there on all the time when headlights are on and looks really cool
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    May 2009
    south yorkshire
    628
    Quote Originally Posted by a3_sline_tdi View Post
    LED Footwell Light Fit For VW Golf 6 Jetta MK5 MK6 Tiguan Touran MA460 | eBay
    fateman's Avatar
    Mar 2014
    42
    Do they fit the A3 as well? They are different part number than the Audi one I found in ETKA 8D0 947 415 vs. 3AD 947 409. Audi ones are much more expensive from what I have researched. Can you compare them and take a photo possibly? Thanks
    May 2009
    south yorkshire
    628
    They fit in my a3 perfectly ,but I think they need a load resistor as they cause an error in vcds
    fateman's Avatar
    Mar 2014
    42
    Thanks, I will order a set then. Was thinking of just sticking the LED strip down the bottom of the door trim but this way it will look much better I guess. Just couple of questions: Are the LEDs replaceable in those lights? can you open them and replace the LEDs for canbus ones so they won't show an error or are they sealed and once they go bust you will need to order a complete light with a casing again?
    May 2009
    south yorkshire
    628
    i know you can open them the led is on a pcb , didnt check about the canbus part but im going to unplug them later anyway and have a look what can be done .
  1. My DIY Guide for Retro Fitting Foot well lights
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2014, 20:19
  2. Foot well Lights
    By stevehall in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th January 2010, 08:36
  3. Retro Fitting Foot well and puddle lights
    Last Post: 30th October 2008, 13:37
  4. '98 S4 Foot Well Lights not working :(
    By GSB1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2007, 17:43
  5. Foot well lighting...... Oh no......
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2005, 12:43
