Chris NottAH Fabrications
    Jan 2014
    7
    Weird knocking/dripping noise when idle (2.0TDI) [VIDEO]
    Hi all,
    I've just started noticing a fairly unusual noise coming from the engine when the car is idle and I was curious if anyone else had the same issue? Not sure if it's just one of those thing as it is a 9 year old car or it will need taking to the garage.
    I uploaded a video on youtube of the noise, find the link below!
    VIDEO0012 - YouTube
    SmithyAG's Avatar
    Dec 2013
    Manchester
    358
    Follow SmithyAG On Twitter
    Sounds like alternator clutch pulley. They are designed to freewheel so the alternator can continue spinning when the revs drop (gear changes and the like).
    When they fail they make that clicking noise. The tensioner that you can briefly see wobbling back and forth gives it away too. I changed mine and the belt whilst I was at it for the sake of a few quid. It's now silent and the tensioner sits near enough perfectly still at idle.
    Edit:
    It could be one of two clutch pulleys, (you can tell by counting the ribs on the belt)
    Darkside Developments - Alternator Clutch Pulley for 1.9 & 2.0 TDi Models - 6 Groove £25 +VAT
    Darkside Developments - Alternator Clutch Pulley for 1.9 & 2.0 TDi Models - 5 Groove £40 +VAT
    Any motor factors will have the aux belt (match number of grooves again), I think I got mine from Eurocarparts for about £8, and it's a continental one too which was a nice surprise
    Jan 2014
    7
    Quote Originally Posted by SmithyAG View Post
    Thanks mate, really useful to know. I'll start looking into getting it sorted!
    SmithyAG's Avatar
    Dec 2013
    Manchester
    358
    It's a straight forward job if you know one end of a spanner from the other. You will need a special tool to get the pulley off the alternator though, like this one : Alternator Pulley Removal Tool Star Torx T50 x 1/2"D | eBay
    Tension is taken off the belt with a 17mm spanner on a square block on the tensioner, and levering it off the belt. There are two holes in the tensioner that line up when you've got it to a certain point, you can put a drill bit through them to hold the tensioner out of the way whilst you fit the new belt.
    I actually ended up changing the alternator because mine had seized to the point where when taking it off it sheared the alternator input shaft.
  1. Knocking/Tapping noise when I turn right at low speed & another problem
    By leewalsh16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th June 2013, 11:14
  2. 2.0 TDI 140 DSG ... starts fine but annoying noise when idling!!!!!
    By AJ-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2009, 10:13
  3. Rattle/ tapping noise when idle.
    By jcp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th August 2009, 09:18
  4. funny noise when idleing on a3 tdi
    By ste_1210 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2008, 14:58
  5. high pitch mechanical noise when idle
    By A4NA18 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2007, 20:11
