AH FabricationsBadger5
    Dec 2012
    Cornwall
    74
    Loud Boost or vacuum noise, please help
    Hi everyone I'm having trouble with my car. Ok il try and explain the best I can, it's an a3 bkd, it feels very slightly under powered, at idle I can hear a slight air hissing noise From the vacuum solenoid block (black box,6 pipes going to it) having someone blip the throttle I can hear a loud hissing noise that I have traced back to around the back of the engine (turbo area) if I unplug the solenoid box the noise stops, and while revving then quickly turning the engine off there is a chatter noise like a Dump valve (sounds like highly boosted jap cars do) from down the front of the vehicle. I really don't no we're to start. There's nothing obvious, have checked pipes ECT, my egr cooler has been removed and the nessasery things blocked off so that rules that out. Anyone come across this before?
    Dec 2012
    Cornwall
    74
    Dec 2012
    Cornwall
    74
    Dec 2012
    Cornwall
    74
  1. weird knocking noise - Please Help!
    By waqi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2010, 22:34
  2. Boost Problem I Think Please Help :(
    By Phil_T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2010, 07:40
  3. Boost or map problem please help
    By djdougalno1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2009, 18:48
  4. high boost screaming noise, please help
    By alkee in forum General Technical / How To
    Last Post: 8th July 2004, 14:52
  5. Consistent TICKING noise? Please help!
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd October 2003, 22:04
