Monster MotorsportEM Tuning
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Help required with fault
    Hi guys.
    Ive be had a fault on going for a while now. I've been led to believe it was the PCV valve. I've been getting the revs flutter after acceleration and going into neutral (see the video). I tested the PCV by removing the oil cap whilst idling and up to temp, you could clearly hear sucking and the car starting to miss.
    Ive vey just replaced the PCV for the new revision R version and changed the gasket. The car is exactly the same as before. My engine code is BHZ if that helps.
    Here re is a video of the rev needle showing how its hunting after accelerating:
    Audi S3 8P fault? - YouTube
    all help is appreciated.
    Mar 2013
    Leicestershire
    425
    My two options left are the check valve pipe work at the back of block or the vac pipes.
    Ill do the easier option first of checking vac pipes. Can anyone tell me the rough locations of them all?
    Mar 2013
    Leicestershire
    425
    I've ordered the check valve pipe and changing that in the morning.
    Does nobody have any suggestions?
  1. Help required with 2006 A6 fuel gauge issues
    By decky1968 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 23rd March 2013, 23:44
  2. More help required with my S4 engine issue
    By tonybolony in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2011, 18:05
  3. Help required with grill part number
    By b19ctr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2011, 20:56
  4. Urgent help required with fault diagnostic codes please
    By dyce martin in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2010, 18:47
  5. Help needed with fault codes
    By j4jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2008, 06:59
