will this fog light switch work i my car?
rory21388
NULL
I am looking to retrofit front fogs to my 57 plate a3 se. I understand I will need a nee switch in order to wire them up. I was planning on buying this -
Screenshot 2014 04 27 10 42 53
However from the pic I can see that the new switch isn't quite the same as my current one. Rather than having adjustment for the headlights it only has adjustment for drls.
This is a picture of my current switch -
IMAG0137
My question is will this switch work? If not can I programme it to work with vcds or am I better looking for a switch that is identical but with the addition of rear fogs?
Thanks,
Rory
The one you planned to buy is for a vehicle that has Xenon headlamps installed and hence doesn't have the range adjuster for the headlamps like yours, so wouldn't work.
I'd say your better doing as you proposed and find a switch identical but with front fogs added.
10
886
6
719
502
938
