Chris NottSky Insurance
Results 1 to 10 of 10
    Mar 2013
    38
    Tail light Retrofit - Parking Light
    Hi! yesterday i install the Led tail lights and when i active the parking light, only de inner works, and in my moms car 8P 2012 the inner and the outer works.
    It is possible to active the 2 lights??
    Thanks!!
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Hi mate!
    In Europe the inner are Fog Lamps! The outer are the brake lights! I believe there's an option to switch them in VCDS. I'm sure someone else will be able to point you to the correct page.
    2009 A3 SB 2.0T DSG S line
    Mar 2013
    38
    Hi!
    The inner have the fog and the reverse lamp, thats OK, but the led dont work when i put the packing light, if i need to put a new code and works it will be great!!
    Thanks!
    Mar 2013
    38
    Nobody??
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Hang on, I'll get the code for my setup
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    This is all in the Central Electronics Module\Coding\Long Coding Helper! All references to the Rear lights are highlighted in Red & the selections are my settings:
    There are also some "back up setting" which I didn't include. Hope this helps, Good Luck
    Mar 2013
    38
    Thanks veryyy muchh!!!!!!
    Later i connect the vagcom a try it!!
    Mar 2013
    38
    This config is from a A3 facelift ?? My car in pre facelift, but i found this,
    Audi A3 Rear Fog Lights
    But this use fog light as taillight, and the LED tail light have light and fog light with diferents bulbs
    Mar 2013
    38
    I think it is no possible in mi car (Pre facelift)
    The only way i think it works is use the same wire that use the outer taillight, it is a little crazy :D
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Did you use a new loom when you installed the units?
  1. Retrofit parking sensors?
    By Naresh in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th March 2011, 22:16
  2. Parking sensors retrofit
    By sworks16 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th April 2009, 09:24
  3. Rear Parking Sensor Retrofit
    By Ian_C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th October 2007, 03:33
  4. Parking Sensor Retrofit
    By A3ontheA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2007, 23:43
  5. Parking Sensors Retrofit
    By VTEC_Killer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2007, 18:08
