Tail light Retrofit - Parking Light
Matuh
NULL
Hi! yesterday i install the Led tail lights and when i active the parking light, only de inner works, and in my moms car 8P 2012 the inner and the outer works.
It is possible to active the 2 lights??
Thanks!!
Hi mate!
In Europe the inner are Fog Lamps! The outer are the brake lights! I believe there's an option to switch them in VCDS. I'm sure someone else will be able to point you to the correct page.
Hi!
The inner have the fog and the reverse lamp, thats OK, but the led dont work when i put the packing light, if i need to put a new code and works it will be great!!
Thanks!
This is all in the Central Electronics Module\Coding\Long Coding Helper! All references to the Rear lights are highlighted in Red & the selections are my settings:
Friday vcds 13
Friday vcds 12
Friday vcds 8
Friday vcds 7
Friday vcds 6
Friday vcds 4
Friday vcds 3
Friday vcds 2
There are also some "back up setting" which I didn't include. Hope this helps, Good Luck
Thanks veryyy muchh!!!!!!
Later i connect the vagcom a try it!!
This config is from a A3 facelift ?? My car in pre facelift, but i found this,
Audi A3 Rear Fog Lights
But this use fog light as taillight, and the LED tail light have light and fog light with diferents bulbs
I think it is no possible in mi car (Pre facelift)
The only way i think it works is use the same wire that use the outer taillight, it is a little crazy :D
