DriverN00B
Okay so the good news is, this is not concerning my car, bad news it's a friends. Been scanned with VCDS and below are the fault codes -
- Motor for Intake Manifold Flap (V157) No Signal P3102 - Intermittent
- Motor for Intake Manifold Flap (V157) Open or Short to Ground P3101
- Fan 1 Control Circuit Short to Ground P0691
- EGR System Insufficient Flow P0401
- Boost Pressure Regulation Limit Exceeded (Over Boost Condition) P0234
- Cylinder 1 Misfire Detected P0301
All 4 injectors were changed a year ago... it's a 2.0 TDi BKD engine, so my main concern would be the Head Gasket going?
However would that cause rough starting and idling, he's described the symptoms as 'Limp mode almost on every drive, blue/white smoke on cold start, shaking/juddering in idle, loss of power, car will literally shake when accelerated in 3rd/4th gear locally nevermind on a stretch'
The car now struggles to start at all, turning over for 10-15 seconds before starting.
Any ideas?
Thanks!
Any ideas?
Thanks!
