AH FabricationsChris Nott
    Feb 2006
    Staffs, Uk
    Drivers seat wiring loom
    As posted previously i'm having problems with the airbag light coming on for short periods of time. I think it has something to do with the wiring at the front of the drivers seat. Is this possible? & if so could a vag.com unit confirm that it is a wiring loom problem. I assume this is caused the wire becoming damaged from the seat being moved. thanks.
    Audi A3 2004 2.0 tdi DSG (over 60kmiles so out of warranty).
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    Re: Drivers seat wiring loom
    You may have a loose connector under the seat?
