EM TuningChris Nott
    Dec 2013
    Manchester
    12
    2006 2.0tfsi rough idle and reving up at lights
    Hi folks,
    i have recently purchased my 2006 2.0tfsi and I have had nothing but trouble since I bought it from a local car dealer, not naming names but it's a Renault dealer in bury.
    My latest problem worries me slightly, it has just covered 66k. I was driving along the motorway for 20 minuets or so before I came off, as I got to the bottom of the slip road and went into neutral the revs half at 3000rpm. I switched the engine off and and started again, this time it sounds like it has a major misfire and idles all over the place, after 30 seconds or so the revs start to creep up to 3000rpm again then drops again and idles rough.
    Your knowledge would be greatly appreciated in helping cure this fault.
    p.s I have felt the car has been underpowered before this but just thought I had got used to the power.
    Many thanks
    kieran
    Madpete's Avatar
    Nov 2013
    Chester
    30
    Coil packs / Plugs?
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,075
    PCV valve. Known issue. Is it really hard to remove the oil cap when the engine is running?
    The part is (iirc) £20 with a new gasket included. Dead easy job, couple of screws to replace. Use a touch of oil on the gasket before fitting and use the chance to clean out your pipes with petrol.
    Pic swiped from vagoc.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Dec 2013
    Manchester
    12
    Hi wuta3,
    The cap isn't particularly hard to remove but there is a small vacuum when I remove it and there is a change in idle speed.
    While I was inspecting I noticed that "great" dealership in bury has left a number of bolts loose.
    Looks like I will be having a trip to Audi and getting my tools out. I will let you know how I get on.
    Many thanks
    Dec 2013
    Manchester
    12
    Hi, just a quick idea, I finally got around to fitting a new breather valve and it drives like a dream again.
    Only 5 mins to fit. Thanks for all your help
  1. A4 tfsi rough idle and fails to start
    By Smythe in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 30th October 2013, 23:20
  2. Very rough idle and emission light on 2.0 FSI
    By cunni319 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2013, 13:36
  3. How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 18:57
  4. Erratic / rough idle in 8P S3 - and how it was fixed
    By cooni in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2010, 02:31
  5. Rough idle and slight backfire!!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2008, 15:22
