JMB RetrofitsEM Tuning
Results 1 to 8 of 8
    Jun 2012
    119
    Is there any A3 8P models that have non-PD engines, please?
    Hi all,
    I currently have a 2001 1.9 TDI 110 SE which has an AHF engine (I think). I run it on 50/50 Diesel/Veg oil and have done for over a year and it runs fine. However, I would really like an 8P model but am not sure if there is such a thing as an 8P model that have the non-PD engines?
    Please could someone answer this for me?
    Thank you all.
    rokape's Avatar
    Jun 2012
    Cornwall
    86
    I asked the other week about this: When did they switch from PD to CR on the 140?
    08 Onwards should be common rail.
    Jun 2012
    119
    Quote Originally Posted by rokape View Post
    Thanks for that but I think you asked a slightly different question. I want to know when they stopped producing non-PD models, Im sure this was soon after the change to 8P but am not positive?
    Mar 2011
    Cleveland
    996
    Well, reading the post, I'd say they made 8p PD engines until 2008? That's 5 years...
    Mine's a 2005 PD.
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    448
    Pretty sure the CR (non PD) engine started with the newer facelift model (with the elephant ears for wing mirrors).
    Think these started second half of 2008, so from 58-plate onwards.
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Oct 2012
    Warrington, North West
    986
    I think he's referring to the older Diesel engines before the PD
    Boon's Avatar
    Sep 2012
    South East Kent
    428
    As said they stopped using PD engines when they started to use CR around 2008!!
    What mods have you made to use veg oil on your current engine? Take it your running single tank if mixing veg & derv?
    I run my nissan vanette cargo on up to 100% veg (down to 50/50 in winter months just for better starting but it will run more veg)
    Current setup is installed a cheap clear inline filter to see any crud (run waste veg oil) into Biotuning plate heat exchanger, into original fuel filter (heated from exchanger) then into the fuel pump. Had to rebuild fuel pump as seals shrunk (Bosch VE) and stripped down, cleaned and rebuilt injectors just so I know they are good!
    Think you'll be hard pushed to find an 8P without either a PD or CR engine suitable for running veg oil. Some can be run with heat exchangers and twin tanking with fuel swop over once everything up to temperature, but not sure if all the sensors and ECU will like it much?!
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Jun 2012
    119
    Quote Originally Posted by Boon View Post
    Thanks for the posts, fellas.
    Boon- Yes, you are right, I run single tank with no mods and she runs just fine on 50/50 in the summer and down to 80/20 in the winter months. Being as my journeys are mostly 5-6 miles I guess a twin tank wouldn't be much use to me as I'd have to wait for it to get up to temperature before switching. Damn it.
  1. Replies: 1
    Last Post: 6th March 2014, 14:08
  2. is there any that can help me do coming and leaving home feature on my a3
    By Bilalmalik in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2013, 22:27
  3. Are there any DPF issues on the 2.0 140bhp engine?
    By themikeyboosh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2013, 21:14
  4. Is there any way of knowing which duel mass flywheel you have
    By a3glenn in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th November 2011, 21:42
  5. 1.8t 190 are there any water pump issues on this model?
    By rog190quattro in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd December 2009, 18:50
Tags for this Thread
