AH FabricationsVolks Autos
Results 1 to 7 of 7
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    424
    Help with possible fault required
    Hi all.
    Not been on in quite a while. I'm getting what I believe to be the start of something failing.
    If I am driving and accelerate in gear with say anything over half throttle, get to 3krpm+ then change gear straight into neutral and effectively Coast! the revs drop down to ~600 then blip to ~1200 and then sit at the idle (~750).
    This may just be nature of the car, I don't know.
    My my initial thought is the PCV valve starting to fail, my car is 57 plate S3 on 43k miles and according to all my receipts from the previous owner, it's still the original valve.
    I have started the car and pulled the dipstick, the idle stays fine but if I rev it slightly it will hunt ever so slightly before resting at ~750rpm.
    Has as anyone got any thoughts or ideas on this of where to look for the cure?
    thank.
    Oct 2011
    Whitby
    29
    I'm getting the exact same problem on 58 plate s3 with 50k, deffo seems its the pcv reading up on it. its join in to get replaced next week so will keep you updated mate
    think this is the part: GENUINE VW VOLKSWAGEN 2.0T FSI PETROL PCV PRESSURE CONTROL VALVE 06F129101R | eBay
    Mar 2013
    Leicestershire
    424
    Cheers mate. I've found a new PCV unit, the type R version for £42 on eBay. I don't know if its worth buying and changing anyway?
    Someone else has mentioned to pull the vac pipes off it one by one whilst idling to see if they're blocked? Not sure if that works or not.
    I've also read, a bit off this topic, about the N80 valve, is this worth changing regardless as good practice? I've not found one online for sale so no idea of cost.
    Oct 2011
    Whitby
    29
    suppose its worth trying the vac pipes, problem with mine is its very intermittent so not guaranteed to do it every time, id just order the part, change it and go from there.
    Not really sure about the N80 valve, need to do a good bit of reading about this car... been too busy enjoying it since I've had it.
    Mar 2013
    Leicestershire
    424
    Yeah I agree.
    My car is due a good service and I've decided I'm just going to do everything.
    Engine oil, filter, gearbox oil, spark plugs, cabin filter, PCV, possible N80, fuel filter, service my ITG intake etc. haldex has already been done.
    Mar 2013
    Leicestershire
    424
    Does anyone know the best place to get a PCV valve, N80 with new pipe and clips and camshaft follower? I don't live local to Audi but would like a invoice to put with my service papers.
    Mar 2013
    Leicestershire
    424
    Anybody else got any views on this?
  1. Help with a fault code???
    By jay1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2012, 22:57
  2. Need some help with a fault code please?
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 09:39
  3. I need some help with some fault codes please
    Last Post: 19th May 2011, 16:14
  4. Can anyone help with these faults...
    By A3Bash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st March 2010, 06:18
  5. Help with recorded fault code
    By Damian s in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2007, 18:33
