Volks AutosAH Fabrications
Results 1 to 10 of 10
    Feb 2013
    Grimsby
    1,100
    Doing first DIY oil change. WOOOOOOAH!
    So im going to do my first ever oil change! WOOOOAHHHH.
    Im sure this is a standard thing to most but im ready for it!
    Iv watched this video, and im just wondering if theres any tips or tricks to doing this smoothy or to watch out for.
    iv got a socket set and torx so all should be good!
    https://www.youtube.com/watch?v=Pp6yFmzwhEU
    Thanks guys.
    05, A3 8P 2.0TFSI Quattro
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Video covers it all.
    Have loads newspapers down to capture any spills.
    Ensure oil is warm.
    Only nip up the sump plug. New copper washer not needed.
    Tom5190's Avatar
    Oct 2013
    Teesside
    177
    Just done mine tonight after work, takes all of 15 min's really.
    The only thing that he doesn't mention is that you need to check the final oil level when the car is on the ground not with the front raised. Do as it states stick 4.5 L in, run the car then top up when the car is on the floor.
    Feb 2013
    Grimsby
    1,100
    so i should run the car to what temp before emptying? a normal 90?
    Sportback owner
    Apr 2007
    France
    496
    If you are using a multi-viscosity oil, such as 10W40 for example, this indicates that the oil is more liquid at cold temperatures than it would be at the normal engine temperature of 90. I believe that it is then better to drain the old oil when it is cold, rather then when it is hot. Anyway, that is what I do. Some folk use a flushing (low viscosity) oil to clean out the engine before putting in the new. Have not tried this so far. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,075
    Also, if you are changing oil filter, prepare for tons of oil to pour out even though you drained the sump.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Tom5190's Avatar
    Oct 2013
    Teesside
    177
    Quote Originally Posted by Geraldy212 View Post
    10w40 means the oil is thickest when cold.
    c_w
    1,061
    Definitely change the oil when it's warm, it doesn't flow as easily when cold, although I have done an oil change before with cold oil (on the assumption that as the engine has stood the oil has fully drained to the bottom) but it just didn't drain half as well out of the sump.
    Feb 2013
    Grimsby
    1,100
    Quote Originally Posted by c_w View Post
    Shud i give it a good drive beforehand? or just run on idle?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Idle will be just fine. 5 mins. Then leave for a few mins so oil can settle.
    If doing it on a drive or porous surface be sure to cover all areas with plastic sheet or 2 layers newspapers.
  1. DIY Oil Change A3 TDI
    By karbonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2014, 18:27
  2. 2012 A3 TDI 170- First Service / Oil Change
    By Marcyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2013, 12:17
  3. DIY Oil Change
    By Bailey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2012, 21:51
  4. DIY Oil change.
    By MURRAYS444 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2010, 17:03
  5. First oil change, When? also, installing a stereo?
    By bluetybo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2006, 08:25
