Volks AutosJMB Retrofits
    Oct 2012
    Grove Park, S London
    Suspension/Steering Gear clunking noise
    Hi Guys,
    I have had a strange clunking/knocking noise coming from the suspension or steering gear for a while now and just cannot figure it out. I am not too well versed in the suspension system but am confident enough to give it a go to fix. It seems to arise when turning right and/or when going over pot holes. It sounds like a lose rod of some sort. I have got under the car and not found anything loose. The car seems to randomly pull to one side when accelerating as well.
    Anyone in the south east who could help me diagnose the problem at least? Or can anyone suggest a good mechanic who can help? I need to get the tracking done desperately as well so maybe ‘2 birds one stone’?
    It is a 55plate 2.0 tdi a3.
    Any advice or contacts would be much appreciated.
    Seenan
    27,097
    Depends where in the south east.
    Oct 2012
    I am in Grove Park but obviously willing to travel. How much would you charge just to have a look and steer me in the right direction?
    27,097
    AMD Essex are out to the east.
    Oct 2012
    Do you think it is worth finding somewhere to do the 4 wheel alignment using that hunter system? or will AMD Essex do the trick? Are they reliable for remaps as well?
  1. Replies: 9
    Last Post: 23rd February 2014, 17:15
  2. Clunking noise at a steer of 90 degrees+ to the right.
    By New2Audi in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2011, 16:16
  3. Clunking noise when changing gear
    By Brendan12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2011, 09:53
  4. Clunking noise when steering
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2009, 16:51
  5. Clunking Noise When Changing Gears
    By JUX in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th May 2008, 21:53
