JMB RetrofitsAH Fabrications
Results 1 to 13 of 13
Like Tree6Likes
  • 1 Post By RPB
  • 1 Post By NHN
  • 1 Post By S3Alex
  • 1 Post By NHN
  • 1 Post By Muzza80
  • 1 Post By S3Alex
Thread: Audi Rs3 brakes...what pads to go for?
    Mar 2014
    38
    I'm after some new pads for my rs3 brake setup. Anyone recommend any? I wanted the ferodo ds2500 but not paying £200 for a set! I've read good things about ebc yellow stuff which are £100 also some brembo pads with anti squeal for £130.
    im driving to Germany soon so will be on the Nurburgring so wanting something decent for fast road use.
    cheers
    kris
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    Kris.
    You've bought a good brake kit and you do need good pads to go with it.
    I've tried some of EBCs pads and whilst some swear by them I thought they were no better than stock Audi pads.
    The DS2500s are a good road going pad and quite honestly if you're going to put the car around somewhere long and fast you want brakes you can trust,not the cheapest you can find.
    I use Mintex 1155 pads on mine which would probably be a bit aggressive but are even better than the DS2500s which I've also used.
    RPB
    Aug 2011
    Notts.
    318
    I had EBC Yellow in my Subaru. I was not really awed by them tbh. I would not buy them again. I don't think they would be any good at all for the Ring. You would do better with the above two suggestions. Mintex or DS2500.
    Besides, you would need the EBC Blues as a minimum for that kind of a drive.
    S3Alex likes this.
    2011 61 plate S3 SB BE DSG - Shark Stage 1 + DSG
    Mar 2014
    38
    New Brembo Sport Pad For Audi TTRS & RS3 | APS
    Anyone know if those are any good?
    27,105
    Even £200 isn't that expensive tbh, you bought an expensive kit, so unfortunately fella it costs a fair bit to run them reliably aswell, so splash the cash :P
    S3Alex likes this.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    Put this another way....
    These are your brakes your talking about,and you want to take the car around one of the most notorious circuits,and to be sure you're going to stop before reaching the scenery.
    Don't pinch on the pads,when you've spent good money on the calipers and discs.
    That's 3 of us saying the same thing now.
    27,105
    +1
    S3Alex likes this.
    Mar 2014
    38
    Ferodo ds2500s it is then.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    Quote Originally Posted by Kris_fenwick View Post
    I think it's worth it.
    I'd used these for a good while with a big brake kit on my car,and they offer good initial bite,and not too much fade on track,which is what you're going to want.
    The S3 is a fairly porky car and needs some decent stopping power....what sort of power is yours running,and what suspension?
    Mar 2014
    38
    Quote Originally Posted by S3Alex View Post
    I have h&r springs and it's just standard power. Gonna sort a performance clutch and stage 2+ when I get back from Germany.
    Waiting for my new tyres to be delivered too, went for Goodyear eagle asymmetric 2s
    Muzza80's Avatar
    Oct 2013
    Glasgow
    559
    I've read that the Brembo HP2000 compound is even better than DS2500, this was what Brembo stated when asked about the Brembo sport pad vs DS2500 --
    � INITIAL BITE ++
    � RESISTANCE TO FADING =
    � AVERAGE FRICTION LEVEL +
    � MODULATION +
    � FRICTION CONSISTANCY =
    � PAD WEAR +++
    � HEAT CONDUCTIVITY =
    � COMPRESSIBILITY -
    � COMFORT (NOISE) +++
    � EASE OF BEDDING +++
    � RESISTANCE TO FADE =
    � LOW BRAKE DUST LEVEL +++
    Tested to the highest levels on the track with decelerations from 270kph (168mph) the HP2000 material is capable of operating in the most demanding conditions.
    Brembo tell us 'this pad has the performance of the Ferodo DS Performance pad, but with improved cold bite'
    With excellent cold performance & bite, high resistance to fade, frictional stability throughout all operating conditions, reduced pad & disc wear and low dust levels, the all new HP2000 friction material offers significant advantages over its rivals.
    Kris_fenwick likes this.
    2010 Audi S3 Sportback Black Edition TFSI Quattro
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Ds3000's would be my choice. Quite aggressive but hell of a pad! My next choice!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,383
    OK....sounds very sensible,rather than maximum attack on a soft setup.
    My own feelings about the S3 are that even with uprated springs,it's quite wobbly when pushed hard,and uprating the ARBs and getting decent coilovers makes a massive improvement,on and off track.
    The Assy 2s are excellent tyres,but do wear quickly.
  1. Audi RS3 Brake Kit New
    By pinterovski in forum For Sale/Wanted - Audi Cars
    Last Post: 3rd September 2013, 18:04
  2. Replies: 17
    Last Post: 21st May 2013, 10:02
  3. Audi A3 8P - What To Look Out For?
    By S3 Boy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2009, 18:52
  4. Replies: 15
    Last Post: 27th May 2008, 20:41
  5. Audi brakes - what's what?
    By corradospy in forum General Technical / How To
    Last Post: 31st October 2003, 22:04
