Sounds like the diverter valve could be faulty.
Pretty easy replacement on the S3 I'm sure there's a guide on here somewhere,
It maybe worth checking what revision you have on an 09 plate, The part number will end in either C or D
Yeah check the diaphragm for splitting and if so get a GFB DV+ valve on it. Far more reliable as it doesnt have a diaphragm inside. It has a little check piston and slide instead.
