Results 1 to 16 of 16
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    330
    Knocking when turning
    Hi.
    My 2.0TDI has a slight knocking noise when turning the wheel. Most noticeable when turning to the right.
    Could this be maybe a bearing or ball joint? Steering?
    Regards
    Chris
    Mar 2012
    52
    Funny I've just came on looking for this same issue, mines when turning continuously like when turning onto a driveway slowly. Mines lowered if that helps.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    330
    Quote Originally Posted by WilkyA3 View Post
    That's exactly what mine is like.
    Noticed it the other day when slowly turning onto the drive. It does it all the time though, you can hear it when turning round a corner slowly.
    I have Eibach sportlines on mine but don't think that will make any difference.
    Yannis's Avatar
    Sep 2013
    44
    Same problem here as well. There seems to be no noise outside the car when the wheel is turned, it just seems to come from behind the steering wheel.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    330
    Quote Originally Posted by Yannis View Post
    There must be an epidemic of the phantom knocking. Hmmmm....
    Any experts on here?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    892
    Yes it could be any joint on the suspension/strut lower arm
    Growing old is mandatory, growing up is optional
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    330
    Quote Originally Posted by LEE69 View Post
    Hi Lee, are they costly to replace?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    892
    depends what as gone, chances are the alignment will need doing afterwards to use Align My Car
    Yannis's Avatar
    Sep 2013
    44
    Where is the knocking coming from?
    I did some reading when I first brought mine and it seems it's the top of the steering rack. Some people took it back to the dealership and had it replaced on warranty and others have just left it as it had no effect on the vehical, just an annoying knocking noise.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    The front ARB may hit the control arm when lowered. This is a known issue and if this is the case with you, than you need adjustable tie rods.
    Other possible reasons:
    - the bracket/s that are holding the front ARB in place are loosen
    - the ARB bushes are worn
    - the tie-rods are worn
    - the steering rack has a problem
    - the top mounts are worn
    - the bearings are worn
    - the drive shaft/s joint/s are worn
    May be some other causes but these are the most frequent.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    330
    Quote Originally Posted by Johnny Bravo View Post
    Many thanks for that, some good options there.
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    I had the same on my A3..... it was the steering rack. If the noise is coming from anywhere within your rack then its a replacement job. Mine had to be replaced (car had done less than 40k miles), luckily under warranty... otherwise its almost a grand fitted if my memory is any good.
    Audi do offer a small (£100-£200) discount on the new rack if you trade in your faulty one.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    330
    Hope it isn't that then! Fingers crossed it's something simple and cheap.
    2008 Audi A4 B8 3.0TDI Quattro S-line (240) in Aruba Blue
    6+1 Gears
    Jun 2009
    Romania
    797
    Try to remove the tie rods from both sides, leaving the ARB free. Than, with the engine on, move the wheels. If there is no knocking than you're closer to the source. Either the tie rods are worn or the bushes/brackets are worn/moving.
    If you still have the knocking with the ARB disconnected, than you may have to check the steering rack.
    Also try and check if there are any marks on the ARB, this would be a sign that it is hitting the arm.
    Mar 2012
    52
    Quote Originally Posted by Djwoody View Post
    Well i also have Eibach Sportlines! About 18 month old. I used to have issues with the spring turning slightly when i first fitted them. I've just had my car serviced and thats when it's appeared since. I wonder if they've disturbed how the springs seated if it's been on a lift or something. I haven't investigated yet but i will be at the weekend.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    330
    Maybe that's what it is then. If you could investigate and let me know that would be great :-)
