Volks AutosMonster Motorsport
Results 1 to 15 of 15
Like Tree4Likes
  • 1 Post By Best84
  • 1 Post By SmithyAG
  • 1 Post By Best84
Thread: Egr clean
    Ron burgundy's Avatar
    Mar 2014
    413
    Egr clean
    Hi
    Does anyone know of an egr removal thread for the tdi 140 bkd engine?
    I've searched but could not find anything .
    Many thanks
    Some people deserve to have eggs thrown at them....brick shaped eggs...made out of brick.
    Grilled Haloumi....mmmmm
    Feb 2012
    Birmingham
    137
    As in to take it off and clean?
    If so unclip the front intake pipe then its just a few allen bolts iirc.
    I cleaned mine about a year ago, thinking of just removing it and having it mapped out now though.
    Mar 2014
    413
    Quote Originally Posted by Best84 View Post
    Hey
    Thanks , is there any specific way that how to unclip the intake pipe? I can see the silver clip thing going around but not sure how to take it off ?
    Sorry if it's easy I'm just trying a bit of diy
    Mar 2014
    413
    I've just got off...just pulled off with a pair of snips
    Feb 2012
    Birmingham
    137
    You dont pull the clip off...just prise it back a bit to release the pipe.
    I used parafin to clean it....very messy job
    Ron burgundy likes this.
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    Follow SmithyAG On Twitter
    The clip doesn't need to come off all together, if you pull it a bit it will click into the service position and allow you to remove the pipe. It pulls out about a cm.
    Mar 2014
    413
    Ok cheers chaps, so I bet that it's going to be a pain to get it back on?
    There's a thin black rubber pipe that's connected , how does that come off ?
    Or have I taken more parts off than just the egr?
    Feb 2012
    Birmingham
    137
    Thats the Egr and shutter valve. i just wiggled it off, just a vacuum pipe.
    You shouldn't have any issues putting it back on unless you drop a bolt, then you have to take the belly pan off, like i did :P
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    The vac pipe will be a tight fit if its never been off before. I used a flat headed screwdriver to ease it off, as just pulling it made it tighter, a bit like those chinese finger puzzle things.
    Mar 2014
    413
    Ha Luckily the belly pan is off as I want to attempt to check the pipes to the intercooler , is that a hard job replacing the seals on the intercooler pipes?
    Mar 2014
    413
    Egr clean
    Quote Originally Posted by SmithyAG View Post
    Lol yeah it wouldn't pull off...well not without great force so the screwdriver worked a treat .
    Mar 2014
    413
    Right my car has 115000 miles on it and last Sunday I used wynns egr clean and sprayed it in to the intake after removing air filter .
    So I've just taken the egr off to give it a proper clean and this is what it looks like before I start...(shutter valve attached as informed )
    It doesn't look to bad does it?
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    Nope doesn't look too bad tbh. The excess crankcase pressure is vented into the intake so it will always be a bit oily. I've seen EGR valves gunged up much worse than that.
    As for the intercooler pipes they are a doddle if you have axle stands/ramps and the undertray off. They are the same connection as the hose that you disconnected from the anti shudder valve. May be worth checking the clips as they seem to get tired and lose their springiness (sp?), which is what holds them tight. I replaced the clips and seals as they were only a couple of quid from Audi.
    Mar 2014
    413
    Ah cool thanks for the info, sounds easy enough , I'll see if my local audi has those in stock in the morning and give it a crack.
    Maybe that wynns egr clean worked and cleaned it out a little , I was expecting it to be really clogged up but happy days either way.
    Mar 2014
    413
    So I've given the egr and shutter valve a proper clean up and refitted....only difference I have found is the idle is a hell of a lot smoother...whether it will stay like smooth who knows...only time will tell.
    Still other issues with car but I'll start another thread if I can't find anything related from a search.
  1. ASV not working properly since EGR clean
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th October 2011, 20:14
  2. 2.0TDI 170 (BRD) - injector cleaners, EGR cleaning, MAF cleaning.
    By brixo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd June 2011, 16:10
  3. EGR cleaning
    By choimaloy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th March 2011, 15:16
  4. A3 EGR CLEANED
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2009, 22:38
  5. EGR Cleaning
    By MartinReid in forum Diesel forum
    Last Post: 7th May 2004, 10:06
