Sky InsuranceBadger5
Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By phil76
  • 1 Post By 15Degrees
Thread: Which Engine
    Dec 2012
    Peterborough
    176
    Which Engine
    Hi Guys
    I want to look at normalising my engine bay somewhat to make it easier to source parts in a hurry.
    So based on the following what base engine type and code would you go for please to achieve 270hp at wheels. It needs to be perky
    Audi A3 8P
    1. I need 270hp exactly at the front wheels
    2. It needs to fit an Audi 6 speed quattro manual gearbox
    3. What turbo and manifold
    4. What exhaust system
    5. What inlet manifold
    6. What intercooler (I might be able to get my Spec R to fit
    7. What cams to reach 270hp off the base engine
    8. What rad (again I might be able to get my Spec R to fit)
    9. What pistons if needed to upgrade
    Spec away as money is not an issue
    PS
    I have a spare CDL engine in my garage, would that do as a starting point?
    Mark..
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    Hi Mark,
    Sorry I wasn't much help with part numbers etc,and I'm sure someone here will have all the numbers you need.
    The K04 is good for up to 360bhp,so that may be a decent starting point,but perhaps a GTX 2867 may fit your needs better,if you plan to track the car.
    All of the aftermarket exhaust companies such as Scorpion and Milltek will build pretty much whatever you require,and if you don't need or want your Spec-R intercooler,I'd suggest giving ProAlloy a call.
    They can do custom work as well as off the shelf fits.
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by S3Alex View Post
    Hi Mark,
    Which base engine though Alex?
    CDL
    2.0 Tfsi BWA?
    I think the 2.0Tfsi is around 200 standard isnt it so perhaps CDl is a better starting point for my needs?
    etc etc
    Lewis583's Avatar
    Mar 2010
    870
    I would try and source an S3 engine as a base to start with to be honest fella. They're stronger than the 200hp TFSi variants.
    From what I understand/have read, they use a 21mm gudgeon pin (lesser TFSi's use 20mm). The pistons stand the abuse better whereas I have read about BWA's cracking the piston rings landings when tuned, though that may only be in very highly boosted set ups I'm not sure.
    I'd be tempted for a S3 K04 hybrid too. Can flow enough up top for the power you need and will also spool at low rpm to give a nice broad torque band for pulling you out of slower corners.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by Lewis583 View Post
    Hi Lewis
    Which engine code is that?
    Mark.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    The engine in my s3 has CDL code. If that helps.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by S. View Post
    Ok im looking at CDL engnes now. Question. Will my helix flywheel and clutch fit? Do the BWA cranks have the same hole spacing as the CDL engine crank?
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    Not sure mate. As for clutch if its 2.0tfsi 200bhp then i guess it should fit, as my mate has the same clutch as me in his mkv.
    don't know for the crank..
    Dec 2012
    Peterborough
    176
    Ok ive gone for the CDL engine. The thing is I seem to be struggling to find an exhaust manifold and turbo. I need the following as these are missing
    Turbo (K04) I guess
    Exhaust manifold
    Oil filter housing
    Downpipe 3"
    Turbo oiling pipe
    Turbo water pipe
    Some re routing of pipes to get it to fit my top mounted Spec R intercooler
    Are there any links for these items? I have searched and searched for S3 exhaust manifold and turbo and cant find anything at all which I find odd.
    Mark.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,064
    Single part number for turbo and mani on CDLA/CDLC
    Mani + turbo: 06F145702C
    Try this site for part numbers and diagrams:
    Audi - A3 - 2012 - Engine, Clutch Teile Katalog (Pats Catalog)
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by wuta3 View Post
    Cheers.
    Any idea where I can buy secondhand?
    wuta3's Avatar
    Jul 2012
    1,064
    Quote Originally Posted by 15Degrees View Post
    Cheers.
    Nope, breakers maybe?
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    You could try Statller in sheffield ,i know they have done a few big turbo conversion lately so they might be able to see if the original owners want to sell the turbos
    15Degrees likes this.
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Dec 2012
    Peterborough
    176
    Update
    I cant use the CDL engine LOL I spoke to jaba sport and my MOTEC wont be able to control direct injection. He recomended a BAM engine with an upgraded turbo for 335 at the fly. I need 270 at the wheels. So im looking at that option now.
    wuta3's Avatar
    Jul 2012
    1,064
    Update
    Isn't the BAM the 1.8t ? I'll swap you my BWA for your CDL+K04 lol
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Dec 2012
    Peterborough
    176
    Quote Originally Posted by mjr901 View Post
    Cant use that buddy as it's also direct injection. My MOTEC M400 can only handle port injection. MOTEC do a new ECU called the M1 but thats 4 grand
    I have specced up a BAM engine now by drooling over the parts on the Bar Tek website (not sure if there is a UK equivalent site). Lots of options for big a Power BAM on there even going stroker if you want 2.2litre. I only need 270 at wheels so im not asking much from it to be honest. I could probably just do the following on a totally standard BAM and be ok
    Rods
    Upgraded IHI Subuaru turbo with mani
    Downpipe to match
    Map it
    The trouble is I have this illness and I start looking at those pages and can't help myself but think oh I NEED that and I NEED that too and I would be silly not to have that, yes just silly and before you know it I have a 5 grand engine build ROFL
    S3Alex likes this.
    Dec 2012
    Peterborough
    176
    Would you buy this?
    1.8t 20v turbo engine agu | eBay
    Saves me a bit of work buying a short block like that to be honest. But AGU was only rated for 150hp so is it as strong as BAM when you get down to it?
    Mark
  1. which engine oil?
    By 08080808 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 23:37
  2. Buying A6...Which Engine?
    By Ewok in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th June 2006, 13:39
  3. Which engine oil? (non - audi)
    By robthehungrymonkey in forum General Chat
    Last Post: 12th April 2005, 15:27
  4. Which engine oil?
    By sssgucci in forum General Chat
    Last Post: 4th January 2005, 15:04
  5. Which engine?
    By Aff in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 21st May 2004, 09:19
