AH FabricationsEM Tuning
Results 1 to 15 of 15
    Icey's Avatar
    Jan 2014
    Northants
    83
    Exclamation Mileage difference from cluster to ECU
    Hi all
    My manager has an audi a4 and just got a cable from the states.
    i have done some mods and on auto scan it comes up the vin number and mileage ok as on dash.
    now when I access the Application tab on VCDS. And read mileage from EcU it comes up nearly 10k more.
    From 73331 to 83kish.
    does that mean it's been clocked ? I know it's 5% but that is more than 10% actually.
    Thanks for your help
    "Understeer" is when you hit the fence with the front of the car.
    "Oversteer" is when you hit the fence with the rear of the car.
    "Horsepower" is how fast you hit the fence.
    "Torque" is how far you take the fence with you.
    -Yeah my signature is stolen, get over it-
    Icey's Avatar
    Jan 2014
    Northants
    83
    Anyone ?
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Looks that way
    Sep 2013
    31
    Do old MOTs add up and maybe check vosa website
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    on mune it comes up in kilometers so looks more as the clocks are in miles
    Jan 2012
    SW London
    794
    I've always seen slight differences on most cars i've worked on. some in the hundreds most in tens. Not as much as that though
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    May 2009
    south yorkshire
    628
    probably been clocked in between mot's even though there is usually a slight difference between ecu and dash .
    Icey's Avatar
    Jan 2014
    Northants
    83
    When I read the ecu in vcds it comes up as mk and miles so there is no confusion of miles or km's
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Mine is massively different too. I've been meaning to look into but I haven't been that concerned.
    One reason is because when I scanned a neighbours car for fault codes there was one that had been logged with a date prior to when the car was built. It didn't give me a lot of confidence in the data in the ECU.
    8P2 S3
    May 2012
    RETFORD, NOTTS
    1,753
    Its not hard to correct mileage in both ecu and clocks, maybe its had a replacement ecu in the past? Either that or whoever clocked it was just lazy. That mileage difference indicates either clocking or a previous failure for sure.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by @udi A3 View Post
    I've had my car since new so I can assure you it's not been clocked.
    8P2 S3
    Jul 2008
    Scotland
    48
    What I was told is that the clock mileage is not that accurate! mine is the same.
    Icey's Avatar
    Jan 2014
    Northants
    83
    Where and how much would it cost to have e mileage corrected ?
    We are not trying any illegal stuff to do just so both mileage add up.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    So the ECU mileage is more accurate? Any way to calibrate the clocks to the ECU?
    2009 A3 SB 2.0T DSG S line
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    Quote Originally Posted by Icey View Post
    £70-150 depending on where you are based. type in mileage correction into google and a whole load will come up.
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
  1. Difference in clusters?
    By chunky79 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th November 2009, 17:51
  2. 01E 6speed gearbox oil different from 02M 6 speed gearbox oil ?
    By adamss24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd October 2009, 15:44
  3. Cabriolet RNS-E differ from Avant and Saloon?
    By Marc1 in forum In-Car Entertainment
    Last Post: 25th May 2009, 17:28
  4. looking at buying an a3 2.0t fsi quattro, what the difference from an s3
    By nick-barnes07 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2009, 07:57
  5. Wheel/tyre size differences from std fit- inaccurate speedo??
    By trekbiker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th October 2005, 19:28
