EM TuningVolks Autos
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By S3Alex
  • 1 Post By Louiekaps
Thread: Service Due - Need Help to Understand Why
    Mar 2014
    Question Service Due - Need Help to Understand Why
    Hi all,
    I'm a newbie here, and I'm really hoping someone can help explain why my 2011 S3 is showing as "service due". I've phoned two different Audi dealers and got two different answers. I'd like to understand the servicing better so I don't get ripped off.
    The car turned three years old this month and has done about 28,000 miles. I bought the car about six months ago and was given a print out of the service history. It states that the current service regime is "New Longlife". It had an oil change June 2013 at 24,000 miles. It had an inspection service August 2012 at 15,000 miles. When I turn on the ignition it now states that the service is due, but I'm not sure why. I checked the DIS a few weeks ago and it showed:
    Oil change in 6100 miles, 99 days
    Service in 15700 miles, 9 days
    I guess the 9 days has counted down to zero and that's why it states service due, but I don't understand it. It's been 19 months since the last inspection service, so if it's time based, why would it show up now as service due? I could understand it if it was 24 months, but it's not. The other weird thing is that the DIS now shows "service in 100 miles". How has it gone from 15700 miles to only 100 miles in a few weeks when the car has only done 200 miles in that time?
    I'm very confused and would really appreciate any comments.
    Regards,
    Chris
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    I had a few problems with the Long Service Interval thing on mine,and a few hiccups with the indications the DIS was giving,so firstly I don't think the thing is infallible.
    One other thing,is a look at the oil coming out of the car at it's first service convinced me that it wasn't a good thing.
    Mine has oil changes every 10 000 miles max.
    2,175
    Ditch the long life service, and change the oil /service every 10K miles or 1 year.
    pluves1's Avatar
    Dec 2008
    353
    Quote Originally Posted by yass247 View Post
    Hi all,
    Regards,
    Chris
    Without realising you've answered your own question.
    In your post above you stated
    That was a few weeks ago. So for the above ready your service is due in 9 days or 15,700 miles whichever is sooner. Try to separate mileage from time or the number of days and then it becomes easier to understand.
    So if you only do say 1,000 miles in 99 days your oil change won't be due till 99 days. If you happen to do 6,100 miles in 60 days then it will be due in 60 days and not 99 days as it originally indicated. Hopefully that makes sense and hasn't confused you further.
    Now
    MY10 BMW 335d Touring (Sapphire Black)
    MY10 S3 Sportback (Sprint Blue)
    Previously
    06 BMW 330d M Sport Touring Le Mans Blue with Black leather, Phone Prep
    Feb 2014
    9
    If you are going to disrepect your wonderful s3, i am going to reposess it from you and bring it with me to the USA. Please respect your motor and change your oil BEFORE 10,000 miles.
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    625
    As has been stated 10,000 miles max. pluves1 explained that well. Another relevant bit of info for anyone that doesnt know, is that you can use VCDS to change the min and max parameters for the DIS to tell you that you need a service. Also - anyone feel free to correct me if I am wrong, but its not JUST miles or time, its also how many cold starts etc etc as well, that the ECU takes into account when determining when a service is due. Id actually love to know just how many factors, besides miles and time, that determine the DIS saying a service is due.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    Feb 2014
    9
    You are correct it does take into account other factors IF you have it set to a flexible interval. You can also set a fixed interval which is straight up miles and time. I believe on ross-techs website it may explain which factors it considers for flexible intervals.
    s3_trev likes this.
    Mar 2014
    Hi all,
    Thanks very much for the comments. Firstly, it sounds like I should get Audi to change it over to fixed interval servicing, especially as I'm still a bit confused with the long life option. I guess what I still don't understand is how it counts down the days until the next service is due. Is it fixed or variable? What I mean is, does it always count down one day at a time, or can it change depending on how the car is driven? For example, could it go: 100 days, 99 days, 98 days, 110 days? If it's a straightforward countdown, then why has it counted down to zero days now? It's been 19 months since the previous inspection. Could it be set to 19 months? I would have thought that it would be set to 24 months if it is time based.
    Thanks again for the help,
    Chris
  1. Need help with a shocking service!
    By MattyW19 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2012, 18:15
  2. MAJOR service due.. Help needed
    By J8TT X in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2011, 09:37
  3. Need help understanding zoom lens please.
    By willnabby in forum Photography & The Digital Darkroom
    Last Post: 27th March 2008, 16:29
  4. Im new and need Help
    By WannabeRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2003, 19:41
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
