Results 1 to 9 of 9
Like Tree5Likes
  • 1 Post By sliced
  • 1 Post By JJ.Foulds
  • 1 Post By Sidhu88
  • 1 Post By ROB A3 Quattro
  • 1 Post By s3_trev
Thread: Disabling self test for reverse light
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Hi all, anyone know how to do this with VCDS? I have tried the most obvious option, of disabling cold diagnosis for the backup light but this unfortunately didnt work.
    I have put this bulb in my reverse light tonight - 1x P21W 50W CREE LED 1156 382 BA15s REVERSE BULBS AUDI DRL DAYTIME DRL BMW | eBay
    and it is a fantastic upgrade, except when I turn the ignition on it pulses 5 times, which I'm not gonna be able to live with. God knows it could happen when i'm driving as well.
    So my thoughts are to turn off the self test to disable this. Any one able to help?
    Thanks.
    Audi S3 8P3 / REVO Stage 1 / REVO Ceramic Intake / NGK Iridium Spark Plugs / LOBA HPFP / Philips Diamond Vision 5000k Fog Light Bulbs /
    KW V3 Coilovers / Team HEKO Wind Deflectors / Bridgestone Potenza S001 92Y Tyres / Complete LED Bulb Conversion (int' + ext') / Ashtray Delete /
    TTS Engine Cover / Alpine 928r Multimedia Station (8in screen) with integrated Bluetooth, Sat Nav etc / Ross-Tech VCDS Owner.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,214
    You''ll need canbus friendly ones mate! return them if possible and get a set of canbus ones
    s3_trev likes this.
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Feb 2013
    Grimsby
    1,094
    HA weird you say this, because i tapped into the footwell lights to install led strips, and everytime i start the ignition these also pulse 4-5 times.
    But they look like a rave a night so i can live with it tbh aha.
    s3_trev likes this.
    05, A3 8P 2.0TFSI Quattro
    Jan 2012
    SW London
    794
    It only happens on start up so i wouldnt worry too much
    s3_trev likes this.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    ROB A3 Quattro's Avatar
    no smoke without poke
    Feb 2014
    145
    50W WHITE CANBUS ERROR FREE CREE P21W 382 BA15s LED CAR LIGHT BULB REVERSE DRL | eBay
    This is the 1 i got no errors works fine a lot brighter than standard can actually c now
    s3_trev likes this.
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Thanks guys.
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Guys just wanted to update you all and tell you I have cured the blinking. First thing I done was try a new bulb. This didnt cure the blinking. So I decided to give VCDS another go, and turns out if you disable cold diagnosis for rear fog light, as well as reversing light, it cures the problem!! Hopefully this helps someone.
    Tonka Toy likes this.
    Feb 2014
    145
    Glad you got sorted hmmm wonder if you can do this for the rear lights I just installed led rear lights and getting bulb out canbus warning did you have the canbus warning as well.
    s3_trev's Avatar
    Nov 2013
    Northern Ireland
    623
    Na mate I never got the canbus warning at any stage. I think its a seperate thing. But im almost certain you could cure any blinking using VCDS and just disabling the cold diagnosis on all of the bulbs. This may cure the canbus too but not sure.
  1. tap which wire for the reverse light (parking sensors)
    By deano1978 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2013, 15:47
  2. reverse lights
    By paul_brad in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2006, 14:34
  3. Reverse light
    By nickel101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2005, 13:29
  4. Reverse lights not working!!
    By imported_richcarthy in forum Classic Audi Forum
    Last Post: 1st October 2004, 14:06
  5. FPA Test for 2004?
    By djmotorsport in forum Motorsport
    Last Post: 6th October 2003, 09:38
