Chris NottMonster Motorsport
    Mar 2014
    EGR Cooler Fault
    Hi Guys,
    I need some advice i got my car booked in for a test as I kept loosing power and the cog lights come on after driving for a while. I paid audi £60 to run some diagnostics and they said seems like this issue is related to the EGR valve but becuase its made differently now they need to change the whole EGR cooler and quoted me £800 .
    Is there anything else that can be done like maybe cleaning the valve? Anyone know any audi specialist in the west midlands that might be able to help.
    I have an A3 1.6 TDI Diesel never had any problems before this with the car and is being serviced regularly.
    tdi-man's Avatar
    Jul 2009
    1,611
    not sure on the 1.6 tdi but you may be able to just remove the whole egr system. I have done this on my 2.0 tdi removed the egr cooler egr valve pipes etc.
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    tdi-man's Avatar
    Jul 2009
    1,611
  1. help needed turbo egr cooler fault a4 blb 2.0 tdi
    By harleymonster in forum General Technical / How To
    Last Post: 30th December 2013, 17:47
  2. EGR cooler torque
    By prs999 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th November 2011, 10:04
  3. 2005 tdi EGR Cooler click
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th September 2010, 10:05
  4. Do 2.0TDI BKD EGR Coolers Really Leak???
    By Tonyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2010, 13:03
  5. 2.0tdi egr valve fault and less MPG!
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2010, 13:55
