Sky InsuranceJMB Retrofits
    tdi-man's Avatar
    Jul 2009
    1,611
    CARS AT THE GARAGE FOR SACHS PERFORMANCE CLUTCH FITTING
    Cars at the garage to get clutch and flywheel fitted due to clutch slip.
    found a problem with the input shaft so waiting to be fixed ;(
    only recon 2 years ago so no biggy I hope.
    lucking forward to the new clutch
    SACHS COVER PLATE - 883082 001422 (NEW PART NUMBER)
    SACHS DRIVE PLATE - 881864 999502
    SACHS SLAVE - 3182 654 150 (NEW PART NUMBER)
    SACHS FLYWHEEL - 2294 000 113
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Keane's Avatar
    Jul 2013
    219
    Cheers for the part numbers where did you order from and how much you pay mate ?
    tdi-man's Avatar
    Jul 2009
    1,611
    £700 including vat delivered trade
    tdi-man's Avatar
    Jul 2009
    1,611
    clutch is all in fault with input shaft all sorted just got to run new 1 in.
    FOR SALE
    1 X SACHS DUAL MASS FLYWHEEL - ONLY DONE 25000
    1 X HELIX UPRATED COVER PLATE . ONLY DONE 15000
    1 X SLAVE
    £100.00 plus postage
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    Quote Originally Posted by tdi-man View Post
    FOR SALE
    1 X SLAVE
    This thread will now be closed as its changed to a for sale thread and not allowed on the main forum. Good luck with the sale. Link below for those interested.
    DUAL MASS FLYWHEEL AND PRESURE PLATE AUDI A3 2.0 TDI 6 SPEED . BKD ENGINE
    Thread Closed.
  1. Sachs Performance Clutch for Audi S3 8P 11/06>
    By bezza in forum For Sale/Wanted - Audi Parts
    Last Post: 12th February 2012, 11:01
  2. Sachs Performance Clutch for Audi S3 8P 11/06> £140 plus delivery...
    By Kelza in forum For Sale/Wanted - Audi Parts
    Last Post: 9th August 2011, 14:33
  3. Sachs Performance Clutch for Audi S3 8P 11/06>
    Last Post: 14th June 2011, 14:54
  4. Sachs Performance Clutch for Audi S3 8P 11/06>
    Last Post: 13th June 2011, 10:04
  5. Cars in the garage now! woohoo
    By doeboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2007, 16:25
