Monster MotorsportVolks Autos
Results 1 to 7 of 7
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    P0183 - Fuel Temperature Sensor fault
    I have this fault and it is pretty persistent, I put in a new sender, the fault stayed, I soldered on an new connector and the fault stayed.
    I just saw that Ross Tech say check the fuse, anyone know which fuse to check?
    From Ross Tech.
    P0183 - Fuel Temperature Sensor A (G81): Open or Short to Plus Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Fuse(s) faulty
    • Wiring and/or Connector(s) from/to Fuel Temperature Sensor A (G81) faulty
    • Fuel Temperature Sensor A (G81) faulty
    Possible Solutions
    • Check Fuse(s)
    • Check Wiring and/or Connector(s) from/to Fuel Temperature Sensor A (G81)
    • Check/Replace Fuel Temperature Sensor A (G81)
      • Check Measuring Value Blocks (MVB)
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Have you logged your fuel temps? Just wondered what VCDS was displaying.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    I had a look a week ago or so and was stuck at something like 39degC
    Westy's Avatar
    Dec 2008
    17,272
    Quote Originally Posted by freegeek View Post
    What engine do you have? I logged my 2.0 TDI last week and when warmed up the fuel temp sat at 60 degrees. So I'd guess if yours is stuck at 39 the sensor might be iffy!
    S3 Build Thread
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    Its a 1.9tdi but its also a brand new sensor, I guess the sensor is just a resistor so I will try measuring it in hot and cold water.
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    Checked the sensor, 600ohms in a cup of hot water amd 10kohms under the cold tap, so the sensor is OK, has anyone else changes a fuse to fix this like recommended by Ross Tech? If there isn't a fuse the it must be a wire break somewhere pretty inaccessible.
    Westy's Avatar
    Dec 2008
    17,272
    Just check all fuses for any blown ones.
    S3 Build Thread
  1. Fuel temp sensor fault??
    By pauldazzle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st July 2013, 11:19
  2. 'How to' photo guide - replacing your Fuel Temperature Sensor on the 2.0 TDi BRD
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th December 2012, 12:09
  3. possible maf sensor fault........ pls help
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2006, 09:24
  4. Temperature Sensor - Display
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2005, 20:39
  5. Replies: 1
    Last Post: 16th May 2004, 11:04
