freegeek
- Joined
- Jun 25, 2008
- Messages
- 163
- Reaction score
- 2
- Points
- 16
- Location
- Dunfermline
- Website
- www.racediagnostics.com
I have this fault and it is pretty persistent, I put in a new sender, the fault stayed, I soldered on an new connector and the fault stayed.
I just saw that Ross Tech say check the fuse, anyone know which fuse to check?
From Ross Tech.
P0183 - Fuel Temperature Sensor A (G81): Open or Short to Plus [h=4]Possible Symptoms[/h]
From Ross Tech.
- Malfunction Indicator Light (MIL) ON
- Fuse(s) faulty
- Wiring and/or Connector(s) from/to Fuel Temperature Sensor A (G81) faulty
- Fuel Temperature Sensor A (G81) faulty
- Check Fuse(s)
- Check Wiring and/or Connector(s) from/to Fuel Temperature Sensor A (G81)
- Check/Replace Fuel Temperature Sensor A (G81)
- Check Measuring Value Blocks (MVB)
