Volks AutosBadger5
    Nov 2013
    13
    Angry S3 Turbo?? .....
    Hi all,
    i have a 58 plate s3 with 47k miles on it
    driving home today i put my foot down a bit and there was a bit a blowing/pop noise and then i have no turbo power for the rest of the way home - no smoke, lights or dodgey noises just no turbo power and a bit of hesistation to restart.
    i have noticed over the last couple of weeks that the turbo whistle has got a little louder (nothing too dramatic), but no loss of power untill now?
    ive had a quick look around and cant see any pipes that are damaged/come off.
    just wondered if anyone had any ideas of what this could be before i take it to the dealers tomorrow..
    cheers
    neil
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,411
    It's possible that one of the boost pipes from turbo to intercooler has blown off,and the lack of smoke etc would tend to agree with that.
    Mine had a similar problem a while back,albeit on higher boost,and this pic shows what I found,looking down the left side of the engine as you look from the front,and down towards the bottom of the engine bay.
    The pipes are not very secure,and rely on a clip and hook type connector to hold the pipe in place.
    Nov 2013
    13
    cheer Alex ill nip and have another look now
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,411
    Quote Originally Posted by S3_Neil View Post
    If it is one of the boost pipes,and they are sods to get at,you can drive it,but be sure to keep the revs low,and not to hoof it.
    If you do,the turbo will almost certainly overspeed due to the lack of resistance and,and also the car will not see any boost,so the potential for that is compounded.
    Nov 2013
    13
    thanks mate. tried to have a look, but cant get to a thing for all the bloody air con pipes. my first thought when it went was a pipe of some sort as, as i said there was no smoke or anything, so think i might limp it to dealers in the morning and let them tackle it.
    thanks again
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Turbo noise
    By AndybS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2003, 21:10
  3. turbo hose set
    By waynehiscock in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2003, 23:24
  4. Hot Turbo Pic
    By mramage in forum Other Brands & Models
    Last Post: 23rd March 2003, 23:36
  5. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
