JMB RetrofitsEM Tuning
    martin_s3's Avatar
    Feb 2014
    Aberdeeen
    85
    Aux part numbers
    Has anyone got the part number for the aux socket aswell as the cables that goes from the socket to the back of the head unit?
    21
    8J0 035 475 - Aux-In Socket
    8E0 973 754 - 4-pin Flat contact housing
    000 979 009 - Repair Wire - you will need 3 of these
    1J0 972 977 G - 32 pin AV connector
    martin_s3's Avatar
    Feb 2014
    Aberdeeen
    85
    That's perfect! Thanks. Much appreciated!
  1. B5 s4 pre facelift aux belt part number
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th March 2009, 14:19
  2. TT linkage for A3 part number
    By phillj in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2003, 16:58
  3. TT pedal set part numbers
    By ooooaudi in forum TT/TT-S/TT-RS Forum
    Last Post: 9th April 2003, 20:20
  4. tt pedal set part numbers
    By ooooaudi in forum General Technical / How To
    Last Post: 9th April 2003, 20:16
  5. ECU part number
    By stumunro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 12:49
