JMB RetrofitsBadger5
    Jun 2013
    Yorkshire
    58
    Advice: Buying A3 TDI 170 S-Tronic BMN
    I'm buying above this afternoon providing it all checks out ok. Apart from the usual i want to ensure the engine and gearbox are 100% more than anything. Its done 92k, So far I've read:
    *Check Engine oil level and coolant and signs of mixing, porous head etc.
    *Check for oil change history on box.
    I was wondering the best way to check the engine for smoke, can you still rev an auto up, ie does it have neutral?
    Do the clutches need changing on s-tronics?
    Can anyone else add to that, I've always had manuals prior so knowledge on auto box is low. Thanks
    56 A3 170 SE S-line S-tronic.
    dantdi's Avatar
    Feb 2008
    kent
    511
    I have the BMN engine. Id make use the injectors have been changed this was a recall.
    Also it has a DPF so bear that in mind.
    Jun 2013
    Yorkshire
    58
    I've got the car now. Love it but found out its had DPF removed and a remap. My issue with that is the boost in relation to throttle position increments is too much. Its s-tronic auto and I only have to press the pedal slightly and it shoots off!
  1. Returning with 4th 8P (A3 S Line 2.0 TDI 170 S-Tronic)
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2012, 20:43
  2. Urgent - Need Advice buying A3 TDI
    By karbonk in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2009, 14:18
  3. Urgent - Need Advice buying A3 TDI
    By karbonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th December 2009, 21:26
  4. Buying A3 TDI 170 Help!
    By Neddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2009, 09:26
Tags for this Thread
