Chris NottVolks Autos
Results 1 to 24 of 24
Like Tree4Likes
  • 1 Post By IQ
  • 1 Post By Rick @ Unicorn Motor Dev.
  • 2 Post By IQ
Thread: Mystery Problem That Has Everyone Baffled
    IQ
    Sep 2011
    16
    Exclamation Mystery Problem That Has Everyone Baffled
    Hi Guys,
    This is my first post and unfortunately it’s to do with a problem!
    I own a 08 remapped and DPF removed A3 2.0TDI PD170.
    About 3 weeks ago when driving home it cut out without warning all the lights came up on the dash and (!)BRAKES came up on the DIS display. I left it a few minutes and it started again, only to cut out again 10 yards down the road.
    Next day I had it up Audi, they did a full fault code scan and it came up with no codes. So it took it back to the remap place and they couldn't find any issues either.
    It’s been fine for the past few weeks but now it’s starting to do it only when the cars been sitting on my drive for the night or when I come to restart it soon after I have turned it off. It would start again if I left it a while.
    Last night it did the same while at a dealership, I left it for a few hours and it wouldn't turn over. So I called out a breakdown van, he did a scan and found nothing, checked the battery and it was fine, disconnected it and still nothing. The brake fluid is full, the brake pads are fine. He tried the trick with unlocking the car with the key and not the fob and it still came up with the same message. He has never come across this either. So I had to get it taken home on a low loader where it’s sitting now.
    Has this ever happened to anyone? Or does anyone have any ideas what it could be? I've tried the spare key and that didn't work either, I've ran out of possibilities now.
    Any help would be more than appreciated!
    Cheers guys
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    Have you checked your battery ?
    warren_S5's Avatar
    Oct 2007
    7,163
    Damaged ECU or wiring loom?
    Water ingress in the scuttle under the windscreen leaking into fuse boxes.
    Poor earthing?
    Audi S5 3.0V6T Coupe Black Edition
    IQ
    Sep 2011
    16
    Hi, yes the battery has been checked it's fine.
    I'll have to check for any water ingress, it could be the ECU, wiring loom, or earthing. How would I check if these are the culprits? Thanks Warren
    Jan 2012
    473
    Have you replaced the battery in the remote?
    IQ
    Sep 2011
    16
    No i haven't replaced the battery, I have used the spare key though and the same thing happened.
    pluves1's Avatar
    Dec 2008
    351
    I'm no expert but, this sounds like the fuel injector problem doesnt it?
    https://www.facebook.com/pages/Fix-t...56033921135623
    Now
    MY10 BMW 335d Touring (Sapphire Black)
    MY10 S3 Sportback (Sprint Blue)
    Previously
    06 BMW 330d M Sport Touring Le Mans Blue with Black leather, Phone Prep
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    Or a crank sensor to me
    IQ
    Sep 2011
    16
    Quote Originally Posted by pluves1 View Post
    The injectors and loom were changed not that long ago at Audi because of the recall.
    IQ
    Sep 2011
    16
    Quote Originally Posted by s3joe View Post
    Is there any way of testing the crank sensor, wouldn't that throw up a fault code?
    pluves1's Avatar
    Dec 2008
    351
    Quote Originally Posted by IQ View Post
    Okay. I'm not a betting man but, if I were, I reckon your current issues are related to this. Again I'm not an expert but, I have read that sometimes the injectors are not adjusted properly. Are Shark Performance on this forum as I think they had some experience of injectors being way outside the specifications.
    Now
    Previously
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Not if it's intermittent
    IQ
    Sep 2011
    16
    This did cross my mind to be honest, because I had the remap before the injectors were changed so I was thinking they might be running slightly wrong. Or could not be adjusted properly from Audi.
    pluves1's Avatar
    Dec 2008
    351
    Audi probably won't know your car has been remapped or had the DPF removed. So my first port of call would be back to the place who did your remap and advise them you've had a new loom and injectors and highlight the issues you've been having. Again I'm no expert but, I'm guessing you may need to pay them for another remap and/or adjusting the injectors. Doubt Audi will be able to do anything as they are putting the car back to spec how it left the factory - unaware of your mods.
    Now
    Previously
    stetheo's Avatar
    Oct 2012
    328
    When I had the injectors replaced under recall on my TDI the clearances were set up completely wrong.
    Took it to Rick @ Unicorn and got them set up correctly. Caused some very lumpy and uneven idle.
    Current:
    8P2 S3 Phantom Black | Sunroof, RNS-E, AMI, FBMFSW, Bluetooth, Auto lights & wipers, CHL, LED Interior light pack, Black Styling pack, Miltek Catback, MY11 rear lights and remapped by Unicorn Motor Developments
    Previous:
    8P2 A3 2.0 TDI 170 S Line Quattro Grey | Remapped
    8L A3 1.9 Tdi 100 Sport Black | Remapped to 130
    IQ
    Sep 2011
    16
    Thanks for your advice mate, I'll have a chat with the guy that mapped it and see what he says regarding this. It would be nice if it is as simple as the injectors just need adjusting.
    IQ
    Sep 2011
    16
    Quote Originally Posted by stetheo View Post
    Yea my car does seem quite lumpy on idle, thanks for the help.
    stetheo likes this.
    IQ
    Sep 2011
    16
    Just thinking, recently I've been smelling what I thought was an exhaust smell from the inside of the car while I was driving. I wonder if it's connected?
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    You need to establish if when the car cuts out, you have communication to the ECU at that point. If the ECU loses communication, then you will get warning lights such as the brakes because these modules can no longer speak to the engine ECU. As soon as it cuts out, try and fault code read or even just establish communication with the ECU. No point in looking at anything else if the ECU is dead.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    IQ
    Sep 2011
    16
    Hi Rick, the only problem now is when ever I turn the ignition on the warning lights come straight on. It wont start again for it to cut out. Its literally dead on my drive. I'm just going to have to get it towed somewhere
    Jan 2012
    Stockport, Cheshire
    748
    Well when it gets diagnosed, that's what needs checking first. I suspect now you will have no ECU comms.
    phil76 likes this.
    IQ
    Sep 2011
    16
    Just wanted to say a massive thanks to Rick at Unicorn Motor Developments for fixing my car. I transported it up to him and he spent the week getting to the bottom of the issue. Turns out it was a wire relay fault and a few dodgy wires, but now its driving perfectly again. I wouldn't hesitate to recommend Rick to anyone, he really knows his stuff and I will definitely be using him again in the future. Cheers Rick.
    warren_S5 and phil76 like this.
    warren_S5's Avatar
    Oct 2007
    7,163
    Brilliant. Nice one Rick for sorting it out. Can you begin to imagine the hassle if you'd have took that to main dealer! Big thumbs up for the VAG independents
    IQ
    Sep 2011
    16
    I know Warren, I'd be crying into my bank statement if Audi were to tackle that job. Long live VAG Independents!
  1. Replies: 55
    Last Post: 23rd December 2009, 23:40
  2. Had a car stolen? or know someone that has?
    By BigDawg in forum General Chat
    Last Post: 5th September 2008, 17:47
  3. Owning an Audi was a dream that has turned into a nightmare
    By MatLamont in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2008, 22:45
  4. I'm looking for a new PC monitor that has freeeview
    By Niknak in forum General Chat
    Last Post: 8th July 2007, 15:41
  5. Buying A Car That has a history?
    By HmanS3 in forum General Chat
    Last Post: 27th February 2007, 09:36
